1992 integra died on the street
Old Feb 6, 2008 | 06:20 PM
Black 92's Avatar
Default 1992 integra died on the street
I have a 92 integra RS automatic. I was driving down the street and all of a sudden my car completely died when it died I noticed that the check engine light turned on. I pulled to the side and put a jump wire in my obd tester i got no flashes. When i got it home(BY AAA) i startrd messing with it and the first thing i noticed was that when i turned the key i did not here the fuel pump kick in or the fuel injectors eather so i went to the junk and got a fuel pump relay i found it bought it and put it in but no luck. so i moved to the next step witch was dropping the tank to check the fuel pump but it works fine. the car cranks over and everything but it does not fire up please help on what i should try next im frusterated.
Old Feb 8, 2008 | 07:19 PM
jadakid88's Avatar
check your ecu fuse!
Old Feb 8, 2008 | 07:59 PM
rockofcali's Avatar
Default Re: (jadakid88)
u got spark?
Old Feb 8, 2008 | 08:02 PM
jhammond_82's Avatar
Reject Papi
Default Re: (rockofcali)
distributor.
Old Feb 8, 2008 | 08:03 PM
iBrandon's Avatar
i would check:
1) If your injectors are getting fuel
2) Getting spark
3) Check all fuses
4) Try another ecu/ Double check all ecu pins on the harness are in tact
5) Change out dizzy, more then likely it could of gone bad
6) check to see if your timing belt hasnt snapped
i would try those..and get back to us
Old Feb 10, 2008 | 01:39 AM
Black 92's Avatar
Default Re: 1992 integra died on the street (Black 92)
Cool thanks for the ideas ill check all of them out and ill get bak at you guys. By the way my buddy has a crashed 1990 integra manual trans. and he said he would let me use the ecu to test it out is it compatible???? thanks for all your help.
Old Feb 10, 2008 | 09:17 AM
B204door's Avatar
na manual and auto ecu's r diferent it mite start it but ur not gona b able to drive it and i dont even think itl let u start it
Old Feb 11, 2008 | 06:27 AM
jadakid88's Avatar
Default Re: (B204door)
no they are the same! the automatic transmission has it on computer(ecu)
Old Feb 11, 2008 | 02:17 PM
cmorris87's Avatar
Your friend want to sell that 90 teg let me know cody_james_morris@yahoo.com
Old Feb 11, 2008 | 02:31 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: 1992 integra died on the street (cmorris87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmorris87 &raquo;</TD></TR><TR><TD CLASS="quote">Your friend want to sell that 90 teg let me know cody_james_morris@yahoo.com</TD></TR></TABLE>
what does this have to do with the thread? noob
Old Feb 17, 2008 | 11:25 PM
Black 92's Avatar
Default Re: 1992 integra died on the street (GRAF-FITI)
ill hit him up about it ill let you know
n15sk4
Jul 13, 2020 04:41 AM
marcosenid
Oct 30, 2008 04:52 PM
deckster333
Sep 10, 2006 10:43 AM
-Gambit-
Jun 27, 2005 04:56 PM
Hondasaurs
Nov 2, 2002 07:21 AM
