oil leak
Old Feb 6, 2008 | 11:39 AM
honda305's Avatar
Default oil leak
i have a sohc and i have an oil leak ive changed the valve cover gasket the vtec solenoid gasket and the distributor o-ring and theres still oil spilling on the block. Is there any other gasket i should change?
Old Feb 6, 2008 | 11:41 AM
JDM_SOHC's Avatar
Default Re: oil leak (honda305)
i'd double check the distributor gasket.. i changed mine a week ago an it was still leaking so when i took it off messed with it a lil an put it back an it was fine... an im single cam too..
Old Feb 6, 2008 | 11:44 AM
EhDriver's Avatar
do u blow any smoke out the exhaust?
honda305's Avatar
Default Re: oil leak (JDM_SOHC)
how do u mess wit a lil o-ring?
Old Feb 6, 2008 | 11:45 AM
honda305's Avatar
Default Re: oil leak (EhDriver)
yes i blow smoke outta the exhaust...i burn oil
Old Feb 6, 2008 | 11:51 AM
fmrprojects's Avatar
if all is repleced and stillleaking, it could be your head gasket
Old Feb 6, 2008 | 11:59 AM
JDM_SOHC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda305 &raquo;</TD></TR><TR><TD CLASS="quote">how do u mess wit a lil o-ring? </TD></TR></TABLE>
cuz one side was flat an one side was round... i put the flatside in the groove so the round part was stickin up an it was fine after that..
id say do a compression test... if any drastic numbers given i'd also say HG...
2kdrift
May 18, 2013 12:00 PM
elmejor
14
Dec 12, 2012 02:30 AM
Bradsxx7
May 30, 2009 10:33 PM
91daINTEGRAda91
Jul 11, 2008 04:57 PM
ZC88CRX
14
Aug 1, 2004 02:02 PM
