oil every where
Old Jul 10, 2008 | 06:52 PM
91daINTEGRAda91's Avatar
Default oil every where
built integra on 14 pounds blowing oil all over the tranny side of the engine bay but i cant find out where its coming from any help would be appreciated
Old Jul 10, 2008 | 07:05 PM
97grnrs's Avatar
Default Re: oil every where (91daINTEGRAda91)
does it still run? u didnt blow a hole in the block ?? if not check the head gasket or oil feed line . look under the distributor..
Old Jul 10, 2008 | 11:37 PM
RedneckRicer's Avatar
Default Re: oil every where (97grnrs)
cam seal? headgasket? Distributor o ring? put your valve cover gasket back on?
Old Jul 11, 2008 | 04:56 AM
2redstars's Avatar
blow-by
Old Jul 11, 2008 | 05:30 AM
totsie7944's Avatar
Default Re: oil every where (RedneckRicer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedneckRicer &raquo;</TD></TR><TR><TD CLASS="quote">cam seal? headgasket? Distributor o ring? put your valve cover gasket back on?</TD></TR></TABLE>
Must be a violate shot of oil if its leaking from the cam seal and making it to the tranny....
Dude I'd get some simple green and clean everything up really well and then start her up and see if you can tell where its coming from. If you still don't see it, I'd do a leak down test and see how the head gasket looks
Old Jul 11, 2008 | 06:03 AM
shortyz21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91daINTEGRAda91 &raquo;</TD></TR><TR><TD CLASS="quote">built integra on 14 pounds blowing oil all over the tranny side of the engine bay but i cant find out where its coming from any help would be appreciated</TD></TR></TABLE>
how in the [freak] should we know where its coming from? ITS YOUR CAR. open your eyes and find it.
Old Jul 11, 2008 | 11:51 AM
A BOOSTED CRX's Avatar
Default Re: oil every where (shortyz21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz21 &raquo;</TD></TR><TR><TD CLASS="quote">
why would you even post this? This doesn't help him at all...your wasting yours and his time..
check all the gaskets again.. are you throwing any cels?
Old Jul 11, 2008 | 11:55 AM
chimmike's Avatar
Default Re: oil every where (A BOOSTED CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by A BOOSTED CRX &raquo;</TD></TR><TR><TD CLASS="quote">
why would you even post this? This doesn't help him at all...</TD></TR></TABLE>
well, him seeing oil all over, then just posting here doesn't help him either.
We're not there, we can't see the engine bay. He'd help himself a lot more by investigating it further than just saying "I've got a massive oil leak, it's everywhere, I don't know where it's coming from."
There are a dozen different places oil could come from, dozens more reasons oil could be coming from those locations.
Old Jul 11, 2008 | 11:56 AM
chimmike's Avatar
what were the last things you did to the car? Try to eliminate options. Did you change the oil? Mess with the valve cover? etc.
we need a lot more information.
Old Jul 11, 2008 | 12:39 PM
welfarepc's Avatar
over filled? seen it before.
Old Jul 11, 2008 | 04:57 PM
rmcdaniels's Avatar
Default Re: (welfarepc)
I did that once when I used a LS head gasket on a VTEC motor. It kind of blew out the back of the motor though.
D Griff
Nov 14, 2009 09:01 AM
Bradsxx7
May 30, 2009 10:33 PM
danielblushtein
Mar 16, 2009 12:33 PM
honda305
Feb 6, 2008 11:59 AM
