Where does this line go to?
as stated above, just a drain... I left mine with the petcock in it so I can drain it manually to avoid contamination.
allstar catch cans are nice... depending on the bung sizes on that one, I think I have the same one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raiden571 »</TD></TR><TR><TD CLASS="quote">just remember that if you route back to the pan, the oil will be contaminated by fuel. </TD></TR></TABLE>
LOL where do you think the **** in the catch/breather can came from?
If you route the line back to the block it just drains back the oil that came out of the block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laocivic »</TD></TR><TR><TD CLASS="quote">Where does the line on the bottom of this catch can go to?</TD></TR></TABLE>
it goes where ever you want when you open the valve, oil will collect in the canister and that is just a drain valve to drain it out, so you can leave the hole open and attach a hose to the engine to let it drain out or drain it into a cup as stated above.
Did you really just say that???
RyanAutry
May 6, 2003 12:37 PM
