Where does this line go to?
Old Feb 6, 2008 | 05:36 AM
laocivic's Avatar
Default Where does this line go to?
Where does the line on the bottom of this catch can go to?
Old Feb 6, 2008 | 05:54 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Where does this line go to? (laocivic)
thats where you drain it from. either into a cup you provide, or back to the pan if the provisions are there for it.
Old Feb 6, 2008 | 07:45 AM
raiden571's Avatar
just remember that if you route back to the pan, the oil will be contaminated by fuel.
Old Feb 6, 2008 | 07:48 AM
twkdCD595's Avatar
as stated above, just a drain... I left mine with the petcock in it so I can drain it manually to avoid contamination.
allstar catch cans are nice... depending on the bung sizes on that one, I think I have the same one.
Old Feb 6, 2008 | 08:56 AM
agrn93ls's Avatar
Default Re: (raiden571)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raiden571 &raquo;</TD></TR><TR><TD CLASS="quote">just remember that if you route back to the pan, the oil will be contaminated by fuel. </TD></TR></TABLE>
LOL where do you think the **** in the catch/breather can came from?
If you route the line back to the block it just drains back the oil that came out of the block.
Old Feb 6, 2008 | 08:58 AM
agrn93ls's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laocivic &raquo;</TD></TR><TR><TD CLASS="quote">Where does the line on the bottom of this catch can go to?</TD></TR></TABLE>
it goes where ever you want when you open the valve, oil will collect in the canister and that is just a drain valve to drain it out, so you can leave the hole open and attach a hose to the engine to let it drain out or drain it into a cup as stated above.
Old Feb 6, 2008 | 10:44 AM
supergenius's Avatar
Did you really just say that???
si0385.
Oct 22, 2006 09:19 AM
mc
Dec 30, 2005 01:50 PM
Novtecdohc
Aug 31, 2005 04:29 PM
BauleyCivic
Oct 16, 2004 08:08 PM
RyanAutry
May 6, 2003 12:37 PM
