rods
Old Feb 6, 2008 | 03:50 AM
inline4wHORE's Avatar
Default rods
i am thinking about buying some eagle h beam rods. Do I have to modify anything to use them in my block?
Old Feb 6, 2008 | 03:51 AM
Default Re: rods (inline4wHORE)
Its a D16z6
Old Feb 6, 2008 | 04:07 AM
i guess there is no help on here right now. i will try later
Old Feb 6, 2008 | 05:01 AM
crazyguy's Avatar
no.u dont need to modify anything.it is a direct bolt on replacement.as long as u buy the right ones for d16z6. are u planning a engine rebuild or maybe boost it ? cause eagle rods are not cheap though.
Old Feb 6, 2008 | 11:36 AM
ddd4114's Avatar
Default Re: rods (crazyguy)
You'll have to notch the block.
Old Feb 6, 2008 | 11:38 AM
fmrprojects's Avatar
Default Re: rods (ddd4114)
if you use them with stock pistons you have to modify but just get some pistons while you at it
Old Feb 6, 2008 | 12:10 PM
Schister66's Avatar
Man U FTW
The block will need to be machined and the stock pistons use a different style wrist pin. You'll have to talk to a machine shop to see if they can make it work for you...
Old Feb 6, 2008 | 01:40 PM
Default Re: (Schister66)
I have heard the notching thing before. I hust was wanting to see what everyone else was doing. I am buying the kit with the je pistons and rings and rods. im doing a n/a thing or maybe a little gas dont know yet
Slow_import
Sep 22, 2006 11:45 AM
thumbtack
Nov 10, 2005 03:55 AM
nota-eg
Sep 27, 2005 09:51 PM
hbkxtbone
Feb 15, 2005 06:14 AM
TurBoXBirD16
Feb 4, 2002 08:54 PM
