added Sta-Bil now my teg wont start.
Old Feb 5, 2008 | 06:16 PM
Hondas_Only's Avatar
Default added Sta-Bil now my teg wont start.
about 2 weeks ago i added some stabil to my tank because my car had been sitting for about 3 months and i was concerned that there could be some problems. that day, the car started just fine, now it just turns over and over and over all day long. the battery is brand spanking new so that's definitely not it.
any ideas? thanks.
Old Feb 5, 2008 | 06:55 PM
ls19integra95's Avatar
Default Re: added Sta-Bil now my teg wont start. (Hondas_Only)
any cels? are your sure your getting spark and fuel? check all your fuses, ground wires to be tight, do you hear fuel pump priming.... check all those and let us know about each them, will help narrow down whats wrong...
Old Feb 5, 2008 | 07:44 PM
no CEL's grounds are good. i'll check on the fuel pump and fuses when i can. good thing its my project and not my daily huh?
thanks
Old Feb 6, 2008 | 07:48 PM
fuses are good... how the heck to do i tell if the fuel pump is priming? i will say that i can definitely smell fuel after i let it crank for about a minute so i'm assuming its working.
Old Feb 6, 2008 | 07:51 PM
Default Re: (Hondas_Only)
when you turn the car from off to the on position without starting it you will hear the humm of the fuel pump coming from under your rear seats...
Old Feb 7, 2008 | 08:00 AM
WalkerGSR1's Avatar
Did you have a full tank of gas when you parked your car?
Old Feb 7, 2008 | 08:21 AM
ac_attak's Avatar
Has the weather been wet? Last time that happened to my car we had tons of rain and i guess the wires or distributor cap was wet because i sprayed some wd40 on them and waiting 10 minutes and it fired up first crank.
Old Feb 7, 2008 | 02:52 PM
Default Re: (WalkerGSR1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WalkerGSR1 &raquo;</TD></TR><TR><TD CLASS="quote">Did you have a full tank of gas when you parked your car?</TD></TR></TABLE>
no. the tank was almost empty. in fact, it actually ran out of gas when i was warming it up and that is what prompted me to get more gas 'laced' with sta-bil. when i added the gas, it started right up... that was about 2 weeks ago.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ac_attak &raquo;</TD></TR><TR><TD CLASS="quote">Has the weather been wet? Last time that happened to my car we had tons of rain and i guess the wires or distributor cap was wet because i sprayed some wd40 on them and waiting 10 minutes and it fired up first crank. </TD></TR></TABLE>
we had rain, but the car is under a car port and covered. i'm going to check the dizzy anyway i guess and see if that's dry. thanks guys
Old Feb 7, 2008 | 03:36 PM
N2O INTEGRA's Avatar
my guess would be that when you ran your tank dry you may have clogged up one or more injectors/fuel filter and thats why it isn't starting.
maybe pull the fuel rail lift out the injectors and see if they all are flowing decently
hope this helps
Old Feb 7, 2008 | 03:57 PM
Default Re: (N2O INTEGRA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N2O INTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">my guess would be that when you ran your tank dry you may have clogged up one or more injectors/fuel filter and thats why it isn't starting.
hope this helps</TD></TR></TABLE>
damn you man! i was hoping that it wasnt something being clogged!!! lol... i've never pulled my fuel rail so this should be fun. by flowing decently, what do you mean?
Old Feb 7, 2008 | 07:44 PM
SuckMyDOHC's Avatar
Always check for fuel and spark first. Could be your distributor
jerryscherry
13
May 8, 2014 10:08 PM
xjm92x
Mar 28, 2011 06:18 PM
ef9itb
Jan 19, 2010 10:48 AM
WavyIntegra
Jan 1, 2010 01:57 PM
Combustion Contraption
Jan 7, 2005 10:40 PM
