Setting Mechanical Timing
Old Feb 4, 2008 | 06:10 AM
maddog20's Avatar
Default Setting Mechanical Timing
I am trying to set Mech. timing on my D16y8.
I am hearing conflicting theories on where to set the timing marks for the Cam Gear.
If I set the cam gear marks to the timing arrows on the plastic behind the cam gear the marks on the gear will be slightly advanced of the cylinder head surface.
If I set the cam gear marks to the surface of the cylinder head it will be 1/2 tooth retarded of the arrows.
Which do I use?
Thanks!
Old Feb 4, 2008 | 06:19 AM
Luserkid's Avatar
Default Re: Setting Mechanical Timing (maddog20)
If you have a back timing cover there is a marking on the bottom that you could line it up to. The bottom of your cam gear should have a marking, line them up and your set.
Old Feb 4, 2008 | 06:35 AM
maddog20's Avatar
Default Re: Setting Mechanical Timing (Luserkid)
I have the OEM cam gear and it doesnt have that mark.
do line up to the arrow or the base of the cylinder head?
Modified by maddog20 at 3:51 PM 2/4/2008
Old Feb 4, 2008 | 06:59 AM
Luserkid's Avatar
quick pic but your off. Also i was thinking of the z6 gear that has the mark, y8 dont have it but you could still follow it if you know it. Basically its where the <FONT SIZE="3">.</FONT> from the 1.6 on the gear. Anyway line up the back cover and the side markings and you will be good.
Old Feb 4, 2008 | 09:24 AM
maddog20's Avatar
being off half a tooth does that really even effect the car?
89ED
18
Jun 22, 2018 03:38 AM
EJ6sedan
Dec 22, 2009 01:27 PM
ef-hatchcrap
Jan 25, 2008 12:45 PM
HybridRacer69
Nov 9, 2007 03:10 PM
97grnrs
May 10, 2007 03:25 PM
