b16a2 oil problem
Old Feb 3, 2008 | 05:43 PM
rustydusty1717's Avatar
Default b16a2 oil problem
it seems my car is burning oil but it doesn't smoke. all stock car so far except for catback exhaust. i rarely drive the car so when i do i drive it pretty hard. does it have to do with vtec? cause when i do drive the car i do hit vtec A LOT. it doesn't use a lot but if i was to drive it for couple days fairly hard cause i don't drive it much then i check the oil it's a little low.
Old Feb 3, 2008 | 05:44 PM
Powered by VTEC's Avatar
Default Re: b16a2 oil problem (rustydusty1717)
it is a well known fact that b16a engine does burn a bit oil. or u can do a compression test on all the cylinders.
Old Feb 3, 2008 | 07:26 PM
how hard is it to do a compression test? i'm gonna be putting on a turbo kit here soon. not running high boost just 7-8 psi but wanna make sure the motors fine first.
Old Feb 3, 2008 | 08:07 PM
electron_si's Avatar
Default Re: b16a2 oil problem (Powered by VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Powered by VTEC &raquo;</TD></TR><TR><TD CLASS="quote">it is a well known fact that b16a engine does burn a bit oil. or u can do a compression test on all the cylinders. </TD></TR></TABLE>
actually to determine if you are losing oil via your oil control rings you need to perform a leakdown test.
Old Feb 4, 2008 | 06:06 PM
okay and how hard is that? is this a serious issue? should i get it checked before i bolt on the turbo?
Old Feb 4, 2008 | 07:23 PM
ahron's Avatar
running high revs does burn oil.
Old Feb 4, 2008 | 07:26 PM
i run my car in high revs most of time
Old Feb 4, 2008 | 07:28 PM
hmtcrxsir's Avatar
Default Re: (rustydusty1717)
but how many quarts of oil you be burning a month? it shouldnt be to an extent that you need to put in a quart every month.
Old Feb 4, 2008 | 07:31 PM
ahron's Avatar
running high revs is one of many differnt reasons of buring oil. i pretty sure ur loosing ur oil because of that. maybe u also have to replace ur O rings also. it should be done every 100,000 miles anyways
Old Feb 4, 2008 | 07:33 PM
ahron's Avatar
Default Re: (hmtcrxsir)
yea.. how much r u buring? if it gets dramatically low in a short period of time.. its not juss revin high
Old Feb 4, 2008 | 07:39 PM
after about 2 weeks of driving it hard i put in maybe half a quart of oil
Longbow
Sep 25, 2011 12:18 AM
Rok_Stok
27
Oct 24, 2009 08:22 PM
Nicks95GSR
Sep 28, 2007 10:54 AM
sepulchral
Mar 26, 2006 04:36 PM
customx_
Mar 18, 2003 05:56 AM
