b16a2 oil problem
b16a2 oil problem
it seems my car is burning oil but it doesn't smoke. all stock car so far except for catback exhaust. i rarely drive the car so when i do i drive it pretty hard. does it have to do with vtec? cause when i do drive the car i do hit vtec A LOT. it doesn't use a lot but if i was to drive it for couple days fairly hard cause i don't drive it much then i check the oil it's a little low.
how hard is it to do a compression test? i'm gonna be putting on a turbo kit here soon. not running high boost just 7-8 psi but wanna make sure the motors fine first.
Re: b16a2 oil problem (Powered by VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Powered by VTEC »</TD></TR><TR><TD CLASS="quote">it is a well known fact that b16a engine does burn a bit oil. or u can do a compression test on all the cylinders. </TD></TR></TABLE>
actually to determine if you are losing oil via your oil control rings you need to perform a leakdown test.
running high revs is one of many differnt reasons of buring oil. i pretty sure ur loosing ur oil because of that. maybe u also have to replace ur O rings also. it should be done every 100,000 miles anyways
Rok_Stok
27
10-24-2009 08:22 PM
sepulchral
03-26-2006 04:36 PM
