P0171 in bank one
Old Feb 3, 2008 | 12:16 PM
ekhatchey's Avatar
Default P0171 in bank one
the code is too lean in bank one thats the o2 sensor in the header before the cat right.
Old Feb 3, 2008 | 12:24 PM
97Ej6mike's Avatar
Could be a fuel issue if your too lean. Generally that would indicate theres not enough fuel (Lean is more air than fuel). Your fuel input may be getting restricted by a bad fuel filter or clogged injectors.
What tpye of motor do you have? What ECU is running it? What significant mods do you have done to the motor?
Old Feb 4, 2008 | 09:42 AM
ekhatchey's Avatar
Default Re: (97Ej6mike)
cant be the injectors cuz i just got a tune up and that was checked by the dealership the only mod is a short ram intake. could it just be a bad o2 sensor?
Old Feb 4, 2008 | 09:48 AM
96hb's Avatar
Default Re: (camarine2003)
I dunno if this will help you, but my wifes truck just had the same code and it ended up being a vacuum leak in the pcv system. I would check something like that and make sure it's not something cheap/easy like a vacuum leak first.
Old Feb 4, 2008 | 11:04 AM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by camarine2003 &raquo;</TD></TR><TR><TD CLASS="quote">cant be the injectors cuz i just got a tune up and that was checked by the dealership the only mod is a short ram intake. could it just be a bad o2 sensor?</TD></TR></TABLE>
A going-bad 02 sensor would cause the car to run rich, as would a broken one as well. When the 02 sensor stops reading, the ECU both 1.) Throws a CEL, and 2.) Runs richer than its supposed to, which kills gas mileage, and causes your motor to generally run sluggish.
How many miles on your car? OEM Fuel pumps, (using as example), rarely ever break, but should that be the problem, it would be whats causing your car to run lean.
Old Feb 4, 2008 | 12:17 PM
ekhatchey's Avatar
well it has been running sluggesh and it takes longer to get up to speed since it came on. i have about 121k. do do u think i should try to take it back to the dealer and have them fix it since something like that is covered under the extended emissions warrenty?
Old Feb 4, 2008 | 01:13 PM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by camarine2003 &raquo;</TD></TR><TR><TD CLASS="quote">well it has been running sluggesh and it takes longer to get up to speed since it came on. i have about 121k. do do u think i should try to take it back to the dealer and have them fix it since something like that is covered under the extended emissions warrenty?</TD></TR></TABLE>
It may be. It definatly wouldnt hurt to bring it back and let them look at it.
Old Feb 6, 2008 | 10:28 AM
ekhatchey's Avatar
thanks for the advice man
Weiro792
Aug 28, 2013 05:42 AM
manuel3655
May 24, 2007 06:22 AM
tr0n9h
Oct 30, 2005 01:33 PM
im a monster hehe
Feb 20, 2004 09:45 PM
Litoman
Aug 15, 2002 07:53 PM
