Need help!!! Dont know what it is..
Old Feb 2, 2008 | 03:33 PM
StreetSoljaz's Avatar
Default Need help!!! Dont know what it is..
OK i have a 93 civic coupe wit a 95 d16z6 swap...It dosnt do this often last time it did this was bout 6 months ago... Well i was in traffic and i had 2 accelerate quickly 2 swithc lanes...When i did the check engine light goes on...After the light being on for about 5 mins... the rpms go real low.. about 2 turn off then jump up.. it will sit normal 4 a few seconds then it will do the same thing again.. it will do this 4 some time... But the car never actualy shuts off.... Then after awhile of it doing this... the rpms stay at 1500rpm on idle and will stay there.. and the car sound lyk a subii... And when im driving i cant past 4000rpm... it will reach 4 but then it sounds like its redlining or something... and the engine gets realy lazy and it eats gas up like nothing... Then 2 day i turned on the car and it was normal no CEL or anything... Anybody kno what this could be??? please help!!!!
Old Feb 2, 2008 | 03:48 PM
z6hatchboy's Avatar
Default Re: Need help!!! Dont know what it is.. (StreetSoljaz)
First thing, check your cel. Sounds like the iacv to me though or possibly the map sensor.
Old Feb 3, 2008 | 04:21 PM
Default Re: Need help!!! Dont know what it is.. (z6hatchboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy &raquo;</TD></TR><TR><TD CLASS="quote">First thing, check your cel. Sounds like the iacv to me though or possibly the map sensor.</TD></TR></TABLE>wats the iacv??? and wat does the map sensor do... and where is it located
Old Feb 3, 2008 | 04:23 PM
i checked the cel code... at first it was throwing 3 diff codes 1 was v-tec selenoid and some others.. i turned the car off and on and it was throwing just 1 21 i think it was
Old Feb 3, 2008 | 04:28 PM
z6hatchboy's Avatar
Default Re: (StreetSoljaz)
Your map sensor will be on the top of your throttle body, it reads the pressure in the intake manifold.
Old Feb 4, 2008 | 05:19 AM
Default Re: (z6hatchboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy &raquo;</TD></TR><TR><TD CLASS="quote">Your map sensor will be on the top of your throttle body, it reads the pressure in the intake manifold.</TD></TR></TABLE> oo ok i just wanted 2 make sure that was it.. i dont have a map sensor... the car never came with it when i bought it...
whats the iacv???
Old Feb 4, 2008 | 05:22 AM
jhammond_82's Avatar
Reject Papi
idle air control valve. just spray some tb cleaner in your tb and see if that helps.
Old Feb 5, 2008 | 05:40 AM
Default Re: (jhammond_82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhammond_82 &raquo;</TD></TR><TR><TD CLASS="quote">idle air control valve. just spray some tb cleaner in your tb and see if that helps. </TD></TR></TABLE> ok ima try that....thanx
Old Feb 18, 2008 | 04:09 PM
well i did it and still nothing.. could it be a sensor?? if so which 1 and where is it located???
Old Feb 23, 2008 | 11:36 AM
ttt anybody know what it could be???
rjmancia
Oct 7, 2008 09:40 PM
kramer06
10
Jan 15, 2008 12:42 PM
JDM manc 10
18
Sep 21, 2006 12:42 PM
sloaccrd
Jun 29, 2005 10:11 PM
champwhiteitr
Mar 17, 2004 03:39 PM
