95mm stroker oil squirters
i was wonderin will i need to remove the oil squirters
or plug them since i will have the 95mm stroker kit
or will the clearance on it be good
im juss tryin to get anyones opinion on this
and if i do have to plug them off will it be safe
to run it with no oil squirters
Didnt you make a thread on this before? If not you, someone else asked the exact same question recently...
You have to seriously bend the squiters, in a gsr block, to use a 89mm ls crank.....so take that into consideration.
= you will probably have to plug for 95mm stroker. But why not just ask Eagle (since thats probably who youre getting it from)
Edit***
You did ask this before...
https://honda-tech.com/zerothread?id=2199059
And I gave you the same answer last time...
Edit***
never mind thats right!! sry bout that
im juss lil tense on gettin it in without
the squirters in place
if u had this setup wat kind of main/rod bearings
would u put in?
would u put in?
NOOdS
13
Nov 28, 2011 02:56 PM
