oil pan gasket
its your call. some cake it on, others don't use any. I put little dabs of it in the corners where the pan gasket angles around the crank, similar to how you put it on the angles of a valvecover gasket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridgeapd »</TD></TR><TR><TD CLASS="quote">its your call. some cake it on, others don't use any. I put little dabs of it in the corners where the pan gasket angles around the crank, similar to how you put it on the angles of a valvecover gasket.</TD></TR></TABLE>
yea ive caked it on once and something happen i ended up dropping the pan again and that hondabond was a bitch to get off.untill i found that wd-40 works good in taking it off.
Not sure about d-series, but my honda dealership recommended "ultraflange 2" to seal the pan on my h22 (NOT hondabond). I'm at 140k and losing oil around the pan, so I expect it to do some good (as well as replacing the little rubber gasket) when I re-seal it. The tube of stuff I think was around $8 from the parts dept.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant »</TD></TR><TR><TD CLASS="quote">I dabbed Permatex Ultra Grey into the four crank-corners, just like on the valve cover.</TD></TR></TABLE>
thats how I do it and I have never had any leak.
Me too. I always just want to be safe.
Me too. Yay!
Me too. Yay!
imadigitalgod
Apr 8, 2010 09:48 AM
