Switched out the ecu for my friends h22 and...problems again. :(
Old Jan 31, 2008 | 07:40 PM
kornmanz's Avatar
Default Switched out the ecu for my friends h22 and...problems again. :(
Ok so if you saw my last thread about my friends car and his problems he basically had idle problems, no vtec, and the car would die many times.
We bought a new ecu and ripped out the old one put in a new on and it starts up fine now, idles smooth as well. However, the engine will not go past 3000 rpms. It bogs down and acts almost like a rev limiter. I'm assuming the engine is basically choking. I think its his ecu and that it needs to be programmed for the engine and this altitude. Am I right?
Video of whats going on is located here:
http://www.youtube.com/watch?v=x4wtrHOWj1o
TheMuffinMan's Avatar
He knows where you live!
Limp mode most likely
Old Jan 31, 2008 | 07:42 PM
kornmanz's Avatar
Default Re: (TheMuffinMan)
Someone else said that too. What is that? And how do I go about fixing it? Or should I just google this? lol
Old Jan 31, 2008 | 07:45 PM
https://honda-tech.com/zerothread?id=2022630
https://honda-tech.com/zerothread?id=1937862
https://honda-tech.com/zerothread?id=1844389
https://honda-tech.com/zerothread?id=1830387
Old Jan 31, 2008 | 07:51 PM
kornmanz's Avatar
Ok so after reading those I'm assuming that we have to fix whatever problem is making his CEL go on before it goes off of limp mode?
Cause his CEL is on. I am going to run a diagnostic with my grandfathers computer (He used to own a shop just last year) and see what the CEL is on for. And then try to figure it out from there.
Old Jan 31, 2008 | 07:57 PM
Boingo
Old Jan 31, 2008 | 07:59 PM
kornmanz's Avatar
Sounds like tomorrow will be fun. Thanks!
user 720822-1
Nov 25, 2008 07:29 AM
5thGeneration
Aug 1, 2007 10:25 AM
mitchtsiawd
Sep 13, 2006 06:52 PM
UeyeMYsi
Honda Civic (2006 - 2015)
Aug 23, 2006 08:08 AM
h22accordturbo
Jun 22, 2002 09:01 PM
