H22 swap in cb7
Old Jan 30, 2008 | 03:56 PM
MFZH22's Avatar
Default H22 swap in cb7
i bought this h22 and i wanna run high compression in it. i bought the pistons but i don't know if i should by rods too? i rather use that money and by a nice valve train with cam's. my question is if the rods are going to take the beat of high compression and should i change the bolts that hold the rods to the crank?
Old Jan 30, 2008 | 04:10 PM
TheMuffinMan's Avatar
He knows where you live!
You realize H22's are high compression to begin with right?
Old Jan 30, 2008 | 04:42 PM
MFZH22's Avatar
Default Re: (TheMuffinMan)
yes yes my engine was a 10:1 and now im taking it to 11:1 and im even modifying the block so i can get rid of the balance shaft's so it revs faster and weight reduction.
Old Jan 30, 2008 | 04:47 PM
Haha, ok.
Making sure you weren't under the impression the H22 was like the F22 (8:1).
You MAY have better luck in the Prelude or All Motor forums. I haven't had much experience with it so I couldn't tell you whether or not you'd need to upgrade the rods.
Old Jan 31, 2008 | 12:06 AM
Alpinestar03's Avatar
If you remove the harmonic balacer the motor may rev quicker but it will greatly effect your motor life.. Its there for a reason.
And its only been proven to make 1-2 hp on a dyno..
You could just save that money for type-s cams or a socket and chipped P28. Which would yeild more dependable and noticeable power gains.
Eric
Old Jan 31, 2008 | 05:23 AM
MFZH22's Avatar
Default Re: (Alpinestar03)
well i thoght of that at the begining but now its done and it looks good. but my questins was that if i need to upgrade my rods if im upgrading the compression?
Old Jan 31, 2008 | 05:48 AM
lilcowboy1984's Avatar
if you spend money/ building, replace the bolts if one breaks it will cost you more than to just replace now, recommend ARP they are the strongest i have heard of. what pistons did you buy? h22's have really strong bottom ends I dont see you having a problem, I read awhile ago about a guy putting S2000 pistons in his H22, he took the rods and crank out of a f22 and it all bolted up. the compression was like a 12:1 but thicken up the head gasket and you can drop that. remember to run the right gas....
Old Jan 31, 2008 | 06:05 AM
MFZH22's Avatar
Default Re: (lilcowboy1984)
thank's for the tip. i boght wiseco 11:1 i wannet to go 12 but if i run that in the engine i had to upgrade to 97octane and that to expensive and hard to get and i still wanna have a street car.
Old Jan 31, 2008 | 06:23 AM
hurleyint's Avatar
Default Re: (MFZH22)
You realize you can't run forged pistons in an H22 without sleeving the block first, right?
And you're worried about rod bolts
Old Jan 31, 2008 | 06:55 AM
GhostAccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alpinestar03 &raquo;</TD></TR><TR><TD CLASS="quote">If you remove the harmonic balacer the motor may rev quicker but it will greatly effect your motor life.. Its there for a reason. </TD></TR></TABLE>
I don't think he was talking about removing his harmonic balancer. I believe that he was refereeing to eliminating the Balance shafts. Did you buy the BS elimination kit or just remove the belt?
Also like Hurleyint said. Say good bye to your H's Fiber Reinforced Metal Sleeves (FRM) and $800 - $1000 out of your wallet to get a set of cast sleeves machined in.
Modified by GhostAccord at 12:07 PM 1/31/2008
Old Jan 31, 2008 | 09:03 AM
MFZH22's Avatar
Default Re: (GhostAccord)
no i didnt by the kit i removed the shafts and i got all the oil plugs plugd so i wodent loose oil presure by not having the shafts and then in the front cover of the block i plugd them with caps where the gears were. and i heard that i dont have to re sleev the block i just have to clean the sleevs well thats what every one is telling me here.
Old Jan 31, 2008 | 09:31 AM
If you did a DIY Balance shaft removal complete with plugs and shaft caps. Share with the rest of us. I spent $125 for my kit. Was your DIY cheaper?
As for the re-sleeve I don't know from personal experience. I'm just going buy what I have read about forged pistons and FRM sleeves not getting along all that well. What would I know. I'm running an F22 that already has iron sleeves. And I'm still cutting them out and slapping a set of cast Darton M.I.D.'s in it. Some might say that is a waste of money. To them I reply piece of mind!
Old Jan 31, 2008 | 11:38 AM
hurleyint's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MFZH22 &raquo;</TD></TR><TR><TD CLASS="quote">i heard that i dont have to re sleev the block i just have to clean the sleevs well thats what every one is telling me here.</TD></TR></TABLE>
read this
https://honda-tech.com/zerothread?id=1250273
Search about this subject, you can find quite a few threads.
Old Jan 31, 2008 | 12:24 PM
You can also use a f series block and you wont have to resleve your FRM sleeved H22 block. You can buy bare f22 blocks around 100 bucks or so. There are a couple f22/h22 hybrid wirte ups and therads in here (accord FAQ, Swaps). I was actually going to do a h22/f23 hybrid but after collecting parts i realized it was taking to long. So i decided to just buy a whole long block and call it a day. Read up in the accord FAQ sticky up top, it sould solve all your questions regarding swaps, accords and other good ****.
You could also buy oem type-s pistions. Which have a 11.0:1 CR. They are cheaper and FRM friendly.
Eric
Old Feb 1, 2008 | 09:48 AM
MFZH22's Avatar
i see what u mean but i did some reserch and the feedback that i got its totaly different some people say that it wount run some people say it will run no problem. so now my decicion is that im going to run forged piston in my stock block and ill see what happenes. now if i wanna put stage 2 cams do i have to change the hole valve train ?
Old Feb 1, 2008 | 09:52 AM
MFZH22's Avatar
no i actually spent a little more that u my was like 150
Old Feb 1, 2008 | 10:37 AM
your going to ruin that block with those pistions... Listen to your peers. And SEARCH. ALL of these answers could be found in the prelude threads. Id post this there and see what they say.
You will need to upgrade your springs and retainers.
But DO NOT USE those forged pistons in a stock FRM sleeved block. It just spells catastrophe. You NEED a iron sleveed block.
Eric
Old Feb 3, 2008 | 07:18 PM
MFZH22's Avatar
yes well i did some reserch and ill talked to some mechanics and they told me is better to re sleeve and if it dont re sleeve is like a 50% chance that it goes welll like it can go bad... so now im thinking if i can gt the money ill probably re sleeve them but if not ill see....
Old Feb 4, 2008 | 11:50 AM
kulrevon's Avatar
It is a preference thing. But if you are going to build the engine any way. It would be cheaper to start out with a f series motor. If you use the F series bottom end you won't have to spend the money on sleeveing it like you would on the H motor.
There is alot of good information on the "frankenstien" engines. In the prelude sec FAQ.
I was building a nice engine before I decided to buy my new car.
I was building f23 bottom end with rsx-R pistons and the h22 head.
Just some incite
popsep3
Oct 2, 2016 11:24 PM
TheProfessional
Oct 15, 2012 03:11 PM
bigdaddyvtec
Feb 24, 2012 03:54 PM
h22aCb7
Mar 5, 2007 02:27 PM
TheNosR
Nov 21, 2006 06:24 AM
