Code 23 problems
Old Jan 30, 2008 | 03:10 PM
jchrm80's Avatar
Default Code 23 problems
Well when driving today for about 15 miles my check engine light came on so I read the ecu and got code 23 from the blinks (obd0). Well I searched on the ecu code list and found that code 23 is a knock indicator.
What I dont understand is why it would trigger this after my engine is already full warmed up. I put 3 bottles of a product called HEET in my tank to try and help pass emissions, but it did not help at all.
I figured the HEET could have caused the check engine light as I added it when I was low on gas(to concentrate in the gas and have more going to my engine). But after I filled it up with 89 octane and started it the light came on again for the same code. I am totally clueless on what to do as my jdm crx w/b16 manual doesnt even list a code 23. Also just to add VTEC still engages. That is th only code displayed and the car still runs normally.
Old Jan 30, 2008 | 04:28 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Code 23 problems (jchrm80)
https://honda-tech.com/zerothread?id=1812135
check here, its for obd1 but you'll still see how to test it
Old Jan 30, 2008 | 09:42 PM
b-16eg's Avatar
Default Re: Code 23 problems (HondaPartsHero)
you should have an output to install a knock sensor. install the knock sensor and wire it to the ecu in the spot of b-19 if problem still occurs try another ecu. i got the jumper harness and put a p28 it doesn't list knock sensor.
ddevault1
Honda CR-V & Element
May 31, 2015 02:26 PM
jchrm80
Jan 30, 2008 04:27 PM
speedKILLS
Jun 10, 2006 12:51 PM
IgniteTeg
Aug 8, 2002 09:26 AM
IgniteTeg
Aug 7, 2002 06:54 PM
