Would a bad thermostat cause cold temps?
Old Jan 30, 2008 | 11:58 AM
johnwohl's Avatar
Default Would a bad thermostat cause cold temps?
Hi! I have my car running now after completing the MPFI swap which is awesome but one thing. The car runs cold all the time. It never gets above 1/4 temp and on the highway it sits right at the bottom of the gauge. Thats ok in the summer but its -15 degrees here right now and I have NO HEAT!! Would a bad thermostat be the cause of this problem?
Old Jan 30, 2008 | 12:13 PM
sgallagher's Avatar
Default Re: Would a bad thermostat cause cold temps? (johnwohl)
If it is stuck open and you have low ambient temps like you are describing, it is possible. The antifreeze/water never have time to warm up inside the engine.
Old Jan 30, 2008 | 12:24 PM
johnwohl's Avatar
Default Re: Would a bad thermostat cause cold temps? (sgallagher)
It's only like $15 so I'll just go ahead and replace it. What is the benefit of a higher temp thermostat like a 195 instead of a 180?
Old Jan 30, 2008 | 12:25 PM
CRX Toad's Avatar
Just building up more heat before the thermostat opens.
Old Jan 30, 2008 | 01:15 PM
johnwohl's Avatar
Default Re: Would a bad thermostat cause cold temps? (CRX Toad)
Awesome, thanks for the help!
Rikaro
14
Jul 23, 2010 09:19 PM
Rob.
Oct 6, 2008 08:34 PM
super jdm yo
Mar 19, 2007 08:58 AM
bumthology
11
Dec 11, 2004 11:23 AM
superstud
Oct 14, 2004 12:44 PM
