type r in civic not reving
i have a b18c jdm type r put it into a 93 dx coupe it does not go anywhere you have to 1/4 trottle it just go if floored it revs up to like 3000 to 3500 and just ***** on itself! i tried everything i wired up everything and have no codes at all!!!! nothing! things i already tried....
-different ecus! p75/p28(chipped and was running fine with the same motor)/p05/p06/p72
-different engine harness
-new fuel pump and filter
-plugs and wires
-main relay
-map-sensor
-tps
-dizzy
i know its not the motor, motor was bought from a good friend of mine we drove it intothe garage and pulled it out to put his new race motor in!!!!
please help !!!??????????????
-plugs and wires
-main relay
-map-sensor
-tps
-dizzy
timing is dead on and has not been touched from honda plus i have a new dizzy brand new from honda i thought maybe the icm chip was expletiveed up or something
is the tps installed correct some. the tps can be a little trick to install. i have seen some ppl get it wrong. make sure it goes up to 4 volt at full throttle
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TYPErCRX »</TD></TR><TR><TD CLASS="quote">timing is dead on and has not been touched from honda plus i have a new dizzy brand new from honda i thought maybe the icm chip was expletiveed up or something</TD></TR></TABLE>
answer both of my questions to steer people in the right direction. help us help you.
was the dizzy installed by you or HONDA?
If you installed it you have to set the dizzy timing. If honda installed the dizzy then take it back to them and have them check the timing?
Do you own a timing gun?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ashb82 »</TD></TR><TR><TD CLASS="quote">is the tps installed correct some. the tps can be a little trick to install. i have seen some ppl get it wrong. make sure it goes up to 4 volt at full throttle</TD></TR></TABLE>
.5v closed and 4.5 WOT.
yea same and we even tryed different ecus the tps is .5 closed and yes 4.5 wot i dont get it at all i have done many swaps and this should have been the easiest!
yes im reading in a honda book and for this kinda of trouble shoot its gives me a list of things of what it could be and the every first once is throttle body! i did change the TB with a gsr one i might try another one
OMG i just figured it out the i knew it had something to do with the fuel so i put a fuel pressure gause on and i was getting 70psi at the filter i was like something is wrong so i took the fuel rail off and i was able to just blow throught it... than i saw what was causeing it the end nut that hold the fuel line on was cause the pressure only to build up in the line and not in the rail i change the nut and it works great now go figure that one out stupid!!!! something must have been clogged in the nut!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy »</TD></TR><TR><TD CLASS="quote">It is common for people to switch those around. If they are correct. Check the ign. timing.</TD></TR></TABLE>
lol i did it.
lol i did it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slo_hatch »</TD></TR><TR><TD CLASS="quote">
lol i did it.
Aye as well.
We were all inexperienced at one point or another.
lol i did it.
</TD></TR></TABLE>Aye as well.
hondaman_csu_slo
Mar 28, 2009 01:34 AM
