vtec
Old Jan 29, 2008 | 01:58 PM
bummax's Avatar
Default vtec
i have a jdm b16a had to replace the ecu with a b18 ecu because the b16a ecu was bad will my vtec still work? how do i no if my vtec working when on boost?
Old Jan 29, 2008 | 02:10 PM
92bubble's Avatar
Default Re: vtec (bummax)
if you get a gsr ecu. but it would be best to stay with the ecu that is made for your motor. or just get a computer chipped to meet your requirements. with boost you will hear vtec the same as you always do.
Old Jan 29, 2008 | 02:12 PM
93egSLEEPER's Avatar
Default Re: vtec (92bubble)
you will need a ecu that supports vtec (p28, p30, p72) or a chipped ecu with a program that supports vtec. You will still hear your vtec engage when your on boost... its more of a sound then feel thing especially when on boost.
Old Jan 29, 2008 | 02:29 PM
bummax's Avatar
Default Re: vtec (93egSLEEPER)
i chiped the ecu with crome
Old Jan 29, 2008 | 02:31 PM
Datphan's Avatar
what basemap are you running the b18 ecu then?
Old Jan 29, 2008 | 02:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bummax &raquo;</TD></TR><TR><TD CLASS="quote">i chiped the ecu with crome</TD></TR></TABLE>
if its chipped and tuned on crome then you should have set a VTEC engagement point when tuning the ECU. with that in mind when you drive wait and listen for VTEC when you get to where you set it.
Dave Brabant
Jun 28, 2018 01:17 PM
trustkill
Dec 4, 2007 04:49 AM
lebrecht22a1
Oct 15, 2006 11:08 AM
vietdragontekx
Dec 21, 2005 05:52 AM
hondaturtle
Mar 21, 2005 10:59 AM
