Swap ideas for boost
i Currenly have a 93 Civic with a b16, i want to swap that b16 for something bigger, i was thinking of a b18C itr, if i was to get the b18C itr block, will i be able to use my b16 components for the b18? such as vtec head, ecu, harness, tranny, etc...?
http://www.hmotorsonline.com/shop/
you can find what kind of motor you want in here...good luck with the build!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicks-eg6 »</TD></TR><TR><TD CLASS="quote">y not a b20 block if your going to swap it all over.... a b20 is bigger... plus if your going to go itr, get the full swap not just the block
thanx, yea with everything i been reading, im going for the b20 and prob. keep the boost at around 17-20 psi. I am now on the search of a b20 block, Local, i would like to pick up myself if anyone here has one, i stay in LA
</TD></TR></TABLE>thanx, yea with everything i been reading, im going for the b20 and prob. keep the boost at around 17-20 psi. I am now on the search of a b20 block, Local, i would like to pick up myself if anyone here has one, i stay in LA
https://honda-tech.com/zerothread/1230496 here is the link to the integra faq check out some of the info in there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SinsEvil666 »</TD></TR><TR><TD CLASS="quote">thanx, yea with everything i been reading, im going for the b20 and prob. keep the boost at around 17-20 psi. I am now on the search of a b20 block, Local, i would like to pick up myself if anyone here has one, i stay in LA</TD></TR></TABLE>
I hope not on a stock bottom... what are you're build plans?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpkmrtoes »</TD></TR><TR><TD CLASS="quote">
I hope not on a stock bottom... what are you're build plans?</TD></TR></TABLE>
oh no, not on stock, well im not that knowledgeable on cars, but i do have my bros and other members of south bay critical that help me out. but im planning on building the block, with some low compression pistons, possibly JE along with rods. want to get some cams in there as well, i will be using my b16 head for the b20, most likely will port polish the head, eldelbrock or skunk 2 manifold, i have an ebay turbo (Turbonetics T3/T4 Stage 3.) tein or skunk 2 full suspension w/ camper kit, type r tranny...stage 4 clutch, still unsure what brand, fidanza aluminum flywheel, AEM fuel rail and other stuff i cant remember, as to numbers in specific, thats way too far out of my league, im still a noob but got the ppl to help me
tfalconier
Jul 18, 2004 09:31 PM
irdprelude
Jun 30, 2002 12:24 PM
