grinding noise?
Old Jan 28, 2008 | 01:56 PM
remixboy123's Avatar
Default grinding noise?
so i have a 99 civic ex with 66k and for some reason ive notcied recently that wheneevr i shift from 2nd gear to 3rd it makes like a minor grinding noise and it feels like something is getting in the way a little bit when i shift? i hope its not a big problem any one know about this?
any information would help a lot, thanks!
Old Jan 28, 2008 | 01:59 PM
slacks's Avatar
Default Re: grinding noise? (remixboy123)
does it sometimes grind in neutral? could be your throwout bearing... when else does it grind?
Old Jan 28, 2008 | 02:01 PM
Default Re: grinding noise? (slacks)
it doenst grind in neutral, only when i shift from 2nd to 3rd for some reason......i tried all the gears and they all shift smoothly just 2nd to 3rd......
Old Jan 28, 2008 | 02:05 PM
slacks's Avatar
maybe a bad syncro? bump for that one. transmissions frighten me
Old Jan 28, 2008 | 02:07 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slacks &raquo;</TD></TR><TR><TD CLASS="quote">does it sometimes grind in neutral? could be your throwout bearing... when else does it grind?</TD></TR></TABLE>
Throwout bearing?
Stop smoking that ****.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by remixboy123 &raquo;</TD></TR><TR><TD CLASS="quote">so i have a 99 civic ex with 66k and for some reason ive notcied recently that wheneevr i shift from 2nd gear to 3rd it makes like a minor grinding noise and it feels like something is getting in the way a little bit when i shift? i hope its not a big problem any one know about this?
any information would help a lot, thanks! </TD></TR></TABLE>
The 3rd gears syncros go out more frequently than every other gear on civic transmissions, they're noted for it. It's your syncro, it's worn, to reduce the problem double clutch - as when you double clutch it eliminates/lowers the work on the syncro.
EDIT:
PS: Obviously you'll have to replace it or something at some point.
Old Jan 28, 2008 | 02:14 PM
slacks's Avatar
Default Re: grinding noise? (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
Throwout bearing?
i was just going on what's wrong with my tranny which grinds in neutral sometimes (or so i've been told it's my throwout bearing)
ep3man
Jul 19, 2008 05:26 PM
scubba
Honda S2000
45
Sep 16, 2007 08:33 PM
f90w
Sep 5, 2007 05:04 PM
Art Vandeleigh
Honda S2000
54
Jun 2, 2007 06:55 PM
FOMULA91
Feb 23, 2005 05:16 PM
