grinding noise?
grinding noise?
so i have a 99 civic ex with 66k and for some reason ive notcied recently that wheneevr i shift from 2nd gear to 3rd it makes like a minor grinding noise and it feels like something is getting in the way a little bit when i shift? i hope its not a big problem any one know about this?
any information would help a lot, thanks!
Re: grinding noise? (slacks)
it doenst grind in neutral, only when i shift from 2nd to 3rd for some reason......i tried all the gears and they all shift smoothly just 2nd to 3rd......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slacks »</TD></TR><TR><TD CLASS="quote">does it sometimes grind in neutral? could be your throwout bearing... when else does it grind?</TD></TR></TABLE>
Throwout bearing?
Stop smoking that ****.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by remixboy123 »</TD></TR><TR><TD CLASS="quote">so i have a 99 civic ex with 66k and for some reason ive notcied recently that wheneevr i shift from 2nd gear to 3rd it makes like a minor grinding noise and it feels like something is getting in the way a little bit when i shift? i hope its not a big problem any one know about this?
any information would help a lot, thanks! </TD></TR></TABLE>
The 3rd gears syncros go out more frequently than every other gear on civic transmissions, they're noted for it. It's your syncro, it's worn, to reduce the problem double clutch - as when you double clutch it eliminates/lowers the work on the syncro.
EDIT:
PS: Obviously you'll have to replace it or something at some point.
Throwout bearing?
EDIT:
Re: grinding noise? (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">
Throwout bearing?
i was just going on what's wrong with my tranny which grinds in neutral sometimes (or so i've been told it's my throwout bearing)
Throwout bearing?
f90w
09-05-2007 05:04 PM
Art Vandeleigh
Honda S2000
54
06-02-2007 06:55 PM
