spun main bearings
ok, so recently I was roughly 170mi. away from home when it happened, so we towed it home and i took out the bearings, wanted to know weather people thought i oughta just get a new motor, or try and get new bearings and stuff and fix this one.. it is a d16a6 in a 91 ed8 civic hatch. motor has roughly 183k miles on it, and the cylinder walls are worn enough to make the engine very loud. so no matter what I do, i gotta take it out to get it rebuilt. so my question is: should i get a b16 or get the d16 rebuilt?
Well, can you handle a rebuild yourself? If you can I'd say go with a set of P29's, and other than that do a standard bottom end rebuild. You'll also want to upgrade the cam/ valvetrain. With the right head/cam/compression combo an all motor d16 will be faster than a B16 swap. But a b16 swap would be a great option too.
i could prolly get the motor out and take the head off and stuff, but i'm pretty sure the cylinder walls have been bored out from years of being hammered on, so id have to send it off to get machined, right? then get larger pistons and rings, get the crank and crank case remaned... bigger bearings and such.. i think... all that sounds quite expensive.. i believe my trans is pretty strong, just have a wicked bad clutch plate thats worn to [expletive]
edit: future plans - in a couple years after i get out of college i think i might want to dabble in the world of turbos..
well, my dad's been a mechanic for 40+ years, im basing that off of what he says.
hatchninja, is there a difference between 1st gen and 2nd gen b16a? i know 2nd gen has 170hp, is it still made for a ef, or is it made for the 92-94 model?
the engine i want to get comes with wire harness and ecu, but im not sure if the wire harness they sell is just an adapter harness or if it is a whole harness... i would think its just an adapter..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kirbyman »</TD></TR><TR><TD CLASS="quote">well, my dad's been a mechanic for 40+ years, im basing that off of what he says.
hatchninja, is there a difference between 1st gen and 2nd gen b16a? i know 2nd gen has 170hp, is it still made for a ef, or is it made for the 92-94 model?</TD></TR></TABLE>
It's OBD-I, so it would be found in 92-later Hondas.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kirbyman »</TD></TR><TR><TD CLASS="quote">the engine i want to get comes with wire harness and ecu, but im not sure if the wire harness they sell is just an adapter harness or if it is a whole harness... i would think its just an adapter..</TD></TR></TABLE>
Where are you getting it from? Usually it'll come with the stock harness for thhe motor, then you need to modify yours to accept the motor. Unbless they specifically say it's an OBD-I upconvert harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">
Where are you getting it from? Usually it'll come with the stock harness for thhe motor, then you need to modify yours to accept the motor. Unbless they specifically say it's an OBD-I upconvert harness.</TD></TR></TABLE>
getting it from jdmcarboy
http://www.jdmcarboy.com/index...73a55
unless you know of a better place for cheaper..
Modified by kirbyman at 9:45 PM 1/29/2008
thanks.. i hope you don't mind me aksing you questions like this.. tis the first time having to rip out the engine... but i finally got it out, but should i get the d15 vtec or the d16 non vtec?
edit: got links for em... i think they should all fit my car, im just not sure besides subtle hp changes, what the differences are... except one having vtec..
zc: http://www.hmotorsonline.com/s...30020 <--looks like mine.
d15 Vtec: http://www.hmotorsonline.com/s...30021
i prefer the d16 over the d15, when you start modifying it, esp with a quality cam, like bisimoto, it really doesn't matter if you have VTEC or not.
Also it has been my experience that the d15b's are overrated in HP. I've seen a lot of strong d16a6's/sohc ZC motors....they seem to be a little stronger than d15b's
Paegelow
Apr 29, 2010 08:43 AM
nix94delsol
Jun 7, 2007 09:01 AM
