Oil leak from ICP??? HELP
Oil is leaking from my intercooler pipe at the point where the IC coupling connects to the turbo. I believe it is coming from the turbo. I have had the turbo rebuilt 3 times and it still does it. My feed line is very small and the return is in a good spot. Any Ideas?
why don't you take off the intercooler pipping of the turbo and look at the turbo outlet and inlet. Your turbo might need oil restrictor if it's leaking.
I guess ill have to check the pressure at the turbo...what do I want it to be. The turbo is a garrett t3/t4 from the drag kit. Pressure?
What is there to know about crank case ventilation.....
