Oil leak from ICP??? HELP
Old Jan 28, 2008 | 01:31 AM
boostedteg4dr's Avatar
Default Oil leak from ICP??? HELP
Oil is leaking from my intercooler pipe at the point where the IC coupling connects to the turbo. I believe it is coming from the turbo. I have had the turbo rebuilt 3 times and it still does it. My feed line is very small and the return is in a good spot. Any Ideas?
Old Jan 28, 2008 | 04:13 AM
DaveF's Avatar
Default Re: Oil leak from ICP??? HELP (boostedteg4dr)
what kind of crank case ventilation are you using, if any ?
Old Jan 28, 2008 | 09:58 AM
Default Re: Oil leak from ICP??? HELP (DaveF)
Stock. What are you thinking?
Old Jan 28, 2008 | 04:56 PM
ABK's Avatar
ABK
why don't you take off the intercooler pipping of the turbo and look at the turbo outlet and inlet. Your turbo might need oil restrictor if it's leaking.
Old Jan 29, 2008 | 02:11 PM
Default Re: Oil leak from ICP??? HELP (ABK)
I guess ill have to check the pressure at the turbo...what do I want it to be. The turbo is a garrett t3/t4 from the drag kit. Pressure?
What is there to know about crank case ventilation.....
young geezer
Oct 20, 2010 08:53 PM
hbyrd8701
Jun 16, 2007 12:19 PM
delsoldrew
Sep 4, 2006 12:56 PM
SynTeg
Jul 28, 2004 01:27 AM
Ntrpriz
Jun 29, 2003 08:10 PM
