turbo keeps blowing on me
Old Oct 20, 2010 | 10:40 AM
young geezer's Avatar
Default turbo keeps blowing on me
ok so i have went through total of 3 turbo so far. first was a precision turbo and it pulled 328 whp on the dyno and on my way home it blew up. after that i bought a used garrett turbo from craigslist and oil was coming out of down pipe's flex pipe like crazy. so i replaced it with used holset turbo from craigslist which looks fine like the other once with no shaft play or anything. right when i put that one on, same thing again. oil was drippin from the flex pipe and from where cool compressor connects to the intercooler piping. so i finally give up and bought a brand new garrett turbo 60-1 and i am scared to put it on and blow it up. there is no kink on the oil return line or anything so i am assuming that may be the oil is coming from the head.
so i was wondering if its ok to connect a stock header on and see if oil is coimng from the header. will it be ok for my motor to run that way when i am tuned for turbo with 1000 cc injectors and all the other good stuff i have for my turbo.
Old Oct 20, 2010 | 10:57 AM
komat's Avatar
Default Re: turbo keeps blowing on me
can you take a picture of you drain setup and also what size oil line are you using.
if the motor is splitting out oil, you will see it on your exhaust port on the head. have you done a compression test to see if the ringlands are blown?
you be fine putting a header back on and driving it around
Old Oct 20, 2010 | 11:22 AM
90Rexx's Avatar
pics of your drain line, tell us about your oil feed setup. PICTURES
also stop buying used turbos lol... alot of people sell turbos on craigslist because they are blown lol.
also what oil are you running
Old Oct 20, 2010 | 06:44 PM
ill try to get the pic up this weekend. i am using -10 for the return line but i am thinking about switching to -12 for my new turbo.
i know i know now. i will never buy used turbo from craigslist.
i am also gonna do a compression test this weekend too. i dont know why i never thought about that.
i am using 10w30 full synthetic oil for my motor.
Old Oct 20, 2010 | 07:10 PM
2k.civic.si's Avatar
quit buying shitty used turbo's. or take one of the ones you have and actually have it rebuilt by a trained professional.
Old Oct 20, 2010 | 07:53 PM
LightningTeg's Avatar
Community Builder
Make sure you using an appropriately sized feed line as well
Old Oct 20, 2010 | 08:52 PM
what do you mean by proper feed line size, what is a proper size and is there there like a combo size for feed line and return line?
Old Oct 20, 2010 | 08:53 PM
CRX Si69's Avatar
you stated your problem yourself twice. stop buying used products, that's why they are on craigslist and not on someone's car. you probably spent more then a brand new turbo would cost you.
hammergunner
May 10, 2008 01:58 PM
steve96accord
Jun 30, 2006 09:40 PM
SynTeg
Jul 28, 2004 01:27 AM
wade
Jul 23, 2004 01:14 PM
