98 b18b1 into 96 ek.
ok guys my buddy is building an ls/v for his teg and is giving me his b18b1 which is a 98 and im swapping it in my 96 ex coupe. im gonna list all of the stuff i believe i need and feel free to correct me if im wrong.
99-00 si linkage
99-00 si rear tranny mount
99-00 si drivers side mount
dont need the a/c bracket because i dont have a/c
only questions i have if the things above are correct is what ecu am i going to need?
and can i buy an after market exhaust for the teg and have it fit my car?
And would h-t like to see pics of the swap into my ek?
thanks in advance
99-00 si linkage
thanks in advance
you can use 94-01 Integra shift linkage
you need the 99-00 Si rear T bracket not the rubber mount
you need the 99-00 Si cast iron cam bracket not the rubber mount here also
use the 98 Integra p75 or get a obd2a to obd1 harness and use a 94-95 Integra p75
the exhaust you dont want to get a integra exhaust for it. it will either be too long/short dont remeber all you have to do is get a b-series manifold and an aftermarket exhaust specific to your year and you will be fine. i had to do it on my ls swaped civic.
1hotintegra
Oct 28, 2003 05:51 PM
