IDLE VALVE CONTROL
Old Jan 27, 2008 | 09:05 AM
thunderboy's Avatar
Default IDLE VALVE CONTROL
Hy I have a problem with my car i think I have a problem with my car idle valve control because the car go idle on 2.5 rpm .what can i do to clean the valve or how to clean the valve and what else can I do to resolve this problem before I go buy a new valve??
Old Jan 27, 2008 | 09:12 AM
ge_ej1's Avatar
Default Re: IDLE VALVE CONTROL (thunderboy)
take it off and clean it....there should only be 2 size 12mm bolts holding it onto your inake manifold....you should see alittle screen in it, cleanthat part out, if it still does idle high, try adjusting your idle screw, it should be to the left of the IACV....turn it with a flat head clockwise to lower your idle or counter clockwise to make your idle higher.....
hope this helps...
Old Jan 27, 2008 | 09:25 AM
thunderboy's Avatar
Default Re: IDLE VALVE CONTROL (ge_ej1)
Ok can i clean it with carb cleaner?? I alraedy try to tight the srew but it still do the same!!The car stay idle hy.What else can I look to low it.
Old Jan 27, 2008 | 09:52 AM
ddd4114's Avatar
Check for vacuum leaks and check your fast idle valve as well.
Old Jan 27, 2008 | 10:24 AM
Slopoke's Avatar
If the idle stays up around 2.5k rpm, check the tightness of your throttle cable, make sure the throttlebody is not stuck partially open, and check for vacume leaks.
If the idle is surging up and down, first check you coolant level, then pull off and clean the idle air control valve(on the back of the intake manifold), then pull off the faste idle valve(on the bottom of the throttle body) and readjust it.
If you search the archives, there are threads on how to do all of this.
turbodailydan
Engine Management and Tuning
Feb 27, 2010 01:07 PM
troyport
Classic Hondas
May 28, 2009 09:06 AM
drock305
Nov 7, 2007 06:56 PM
mafiaboy757
Jun 9, 2005 08:02 PM
