Disturbing sound
Old Jan 26, 2008 | 10:04 PM
johnclaunch's Avatar
Default Disturbing sound
Now, on cold mornings (<35F) when I start my car for the first time of the day (after sitting over night) SOMETIMES I get a sound a fraction of a second after the engine starts that sounds almost like a faint sound of a starter grinding. It is very brief and doesn't happen every cold start just once and a while. Now, I have owned this car since April of 2006, and it went through last winter with no issues or noises and I didn't notice any noise this season until my last oil change when the only thing I did differently was use a Mobil 1 filter instead of my usual HAMP filter. I changed filters because after 3K miles, the oil was dark, so I figured I would use a different filter. After a few times of hearing the sound, I had a Valvoline filter put on by my oil change shop and the sound stopped for a few days. Then on Friday I heard the noise again and had a full oil and filter change. Today I got the sound very briefly when I first started the car. I thought maybe it was a valve noise? A partially clogged oil filter will restrict oil flow to the top of the engine, so that might be the cause of the noise, but I can never replicate it when someone is around to hear and give some insight. Someone said that it might be the oil pump and to have Honda check it out. Also, I remember getting a bulletin from Honda a while back about the ABS system making a noise at startup while it resets itself or something. I have never noticed the sound before and it is bothering me. Also, I started using Lucas gas treatment (upper cylinder lubricant) at the same time I had the Mobil 1 filter put on and have been using it ever since. I have never used the Lucas product in my car before, but I used it all the time in my old 91 EF and never had noises or issues. Any insight is appreciated.
Old Jan 27, 2008 | 05:43 AM
WyldRice's Avatar
Default Re: Disturbing sound (johnclaunch)
LOUDER AND HARDER!
if it's not getting any worse, and no side effects... i'd say crank the music!
(it works on my steering creak!)
6 Great speakers, Dual Sub Box + 1600+ Watts could do the trick!
Old Jan 27, 2008 | 08:51 PM
Default Re: Disturbing sound (WyldRice)
WyldRice... PM me.
Old Jan 28, 2008 | 06:21 AM
WyldRice's Avatar
sorry- i'm not good with computers... maybe i'm doing the IM's wrong?
i have IM'd many people here, but only 1 has responded, and that was months ago...
so i gave up trying to im people...
but as far as the noise, i've never heard of it.
i would have someone get under the hood WHILE its cold, and then start it...
and try to isolate where the sound may be coming from...
sorry i don't have any other (GOOD) advice, but i'll pray for you and the car!
God bless!
Old Jan 28, 2008 | 11:12 AM
dc5tegk20's Avatar
I have the same exact situation! I was like WTF. It sounds just like a engine grinding. If you click the key over and let the engine light click off, if wont do it.
Old Jan 28, 2008 | 10:37 PM
Default Re: Disturbing sound (dc5tegk20)
Okay, so if I wait for the CEL to go off, it won't make the noise?
Old Jan 28, 2008 | 11:23 PM
dc5tegk20's Avatar
so far, if i let the light turn off and then start it, it doesn't make the noise!
Old Jan 29, 2008 | 08:55 AM
WhiteOnRice's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WyldRice &raquo;</TD></TR><TR><TD CLASS="quote">i would have someone get under the hood WHILE its cold, and then start it...
and try to isolate where the sound may be coming from... </TD></TR></TABLE>
Definitely do this
Old Jan 29, 2008 | 09:45 AM
DC5Chris209's Avatar
Default Re: Disturbing sound (WhiteOnRice)
My type s just started doing that this winter never did it this summer it gets around 35-40 degrees here.
It almost sounds as if it the starter sticking.
My friend has an a2 swap and has had the samething happen.
Maybe it is a recall?
Old Jan 29, 2008 | 07:43 PM
Default Re: (dc5tegk20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc5tegk20 &raquo;</TD></TR><TR><TD CLASS="quote">so far, if i let the light turn off and then start it, it doesn't make the noise! </TD></TR></TABLE>
Does the oil pump start pumping before the engine is cranked? Maybe the oil pump starts pumping and gets oil to the top of the engine in the amount of time for the CEL to go off??
Old Jan 29, 2008 | 10:44 PM
dc5tegk20's Avatar
Default Re: (johnclaunch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnclaunch &raquo;</TD></TR><TR><TD CLASS="quote">
Does the oil pump start pumping before the engine is cranked? Maybe the oil pump starts pumping and gets oil to the top of the engine in the amount of time for the CEL to go off??</TD></TR></TABLE>b]Before, its instant. My friend told me that he thought it was the oil pump also.
iplayloudly
Jan 2, 2009 07:21 PM
prelude_93vtec
Feb 4, 2008 01:24 PM
Smitty2000
Sep 7, 2007 05:41 PM
2005 TSX
Dec 10, 2003 03:23 PM
