Help: Engine Noise?
Old Dec 9, 2003 | 06:21 AM
2005 TSX's Avatar
Default Help: Engine Noise?
I have some concern with my car...here's the problem:
After every oil change, I notice that my car makes a "pinging" sound. The sound only occurs below 2000 rpm, and is very noticeable between 1500 - 1800 rpm. The engine can be cold or hot, does not make a difference, the sound still occurs.
I bought the car off the lot, and I know that the engine is stock. No modifications at all. (Well just a K&N replacement air filter !)
The car has 39,000 pampered miles on it...a few beatings every now and then !
I had a valve adjustment at an Acura dealership about 5000 miles ago.
For my oil changes (every 3000 miles), I use Penzoil 5W-30, and a Mobil-1 Oil filter.
I always make sure that there is enough oil in the car...right on or slightly below upper mark of the dip stick.
One thing that I did notice is that after awhile the noise goes away. Could it be that the oil is thickening up after time/age/miles and lubricating better at lower engine speeds? Should I be a using a heavier weight oil...or maybe even a different oil for my next oil change? Does Penzoil just suck ?
At first I thought that maybe it was the quality of fuel. I have tried different gas stations: Shell, Chevron, 76. No change.
And I haven't changed the spark plugs/wires yet either. They are the original plugs/wires that came with car. Could this also affect the engine noise at lower rpms?
Any help would be greatly appreciated.
Modified by 2001 Integra GSR at 5:57 AM 12/10/2003
Old Dec 9, 2003 | 10:49 AM
2005 TSX's Avatar
Anyone?
Old Dec 9, 2003 | 03:17 PM
2005 TSX's Avatar
Does anyone have any clues?
Old Dec 10, 2003 | 04:26 AM
JimBlake's Avatar
Default Re: Help: Engine Noise? (2001 Integra GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2001 Integra GSR &raquo;</TD></TR><TR><TD CLASS="quote">After every oil change, I notice that my car makes a "pinging" sound. The sound only occurs below 2000 rpm, and is very noticeable between 1500 - 1800 rpm. The engine can be cold or hot, does not make a difference, the sound still occurs.</TD></TR></TABLE>Is this just for a few seconds the first time you start after changing oil? That's kinda normal, but I wouldn't be revving the engine until the filter is full & the new oil is circulating.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2001 Integra GSR &raquo;</TD></TR><TR><TD CLASS="quote">I had a valve adjustment at an Acura dealership about 5000 miles.
I always make sure that there is enough oil in the car...right on or slightly below upper mark of the dip stick.</TD></TR></TABLE>Did they have the car long enough for the engine to be completely cold? You gotta do valve adjustments like that. It sounds like you're OK for oil...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2001 Integra GSR &raquo;</TD></TR><TR><TD CLASS="quote">One thing that I did notice is that after awhile the noise goes away. Could it be that the oil is thickening up after time/age/miles and lubricating better at lower engine speeds? Should I be a using a heavier weight oil...or maybe even a different oil for my next oil change?</TD></TR></TABLE>Oil usually gets thinner with use.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2001 Integra GSR &raquo;</TD></TR><TR><TD CLASS="quote">At first I thought that maybe it was the quality of fuel. I have tried different gas stations: Shell, Chevron, 76. No change.</TD></TR></TABLE>Premium gas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2001 Integra GSR &raquo;</TD></TR><TR><TD CLASS="quote">And I haven't changed the spark plugs/wires yet either. They are the original plugs/wires that came with car. Could this also affect the engine noise at lower rpms?
Any help would be greatly appreciated.</TD></TR></TABLE>The Pt plugs are supposed to go 60k miles on my '95 GS-R. I suppose that's the same? I think with your OBD-2 you can't change spark timing. Besides, GS-Rs have a knock sensor to protect against spark knocking.
I'm probably not much help without hearing the noise firsthand...
Old Dec 10, 2003 | 05:34 AM
PLRacer's Avatar
Default Re: Help: Engine Noise? (JimBlake)
i have the same problem. after i changed my oil, the engine now ticks. although mine only accurs when the engine is warmed up. i know its not the spark plugs or wires cuz i had brand new ones on. i did a valve adjustment but no change.
Old Dec 10, 2003 | 02:19 PM
1hotintegra's Avatar
Default Re: Help: Engine Noise? (PLRacer)
its the oil filter.. its filled with air... to help this i prime the oil filter with oil before the oil change u can fit like 3/4 quart in the oil filter... its kinda funnny
Old Dec 10, 2003 | 03:23 PM
J98BlueGSR's Avatar
Default Re: Help: Engine Noise? (1hotintegra)
Question: Does this sound occur when the clutch is out or in or doesn't matter?
Only reason I ask is that my friend had 96 teg which started making ticking noises, and sometimes they went away, but then later on, from ignoring the sound, the sound got louder sometimes, and then his clutch wouldn't work. We took the trans out and found many bolts were loose and the clutch needed to be replaced. So if you have been beating on your car, running at the track at all alot, or just recently over the summer I would suggest checking that out.
Not sure if this would be the problem, not oil related at all either, just trying to help!
Randomkoko
Honda Fit
Jul 15, 2017 11:01 AM
Pac______
Mar 23, 2017 11:35 PM
johnclaunch
10
Jan 29, 2008 10:44 PM
Smitty2000
Sep 7, 2007 05:41 PM
jh2586
Dec 3, 2005 06:51 PM
