garrett tb03 good for low boost in B18CRX?
just as the title says, im just looking for a quick daily driver, nothing really crazy. will this t3 be pointless is such a high revving motor? btw it has a .52 compressor side and .48 exhaust.
ok so from what ive read, this little snail in off a 2.4 liter dohc 16valve chrysler motor that was good for 224hp @ 11psi (<correct me if im wrong on this.). im looking to add maybe 6-7 psi on a stock gsr, what numbers should i be expecting? heres a picture of it.
It has probably a stage 1 turbine wheel and the small A/R .48 turbine. That will make your torque/power drop very quickly at higher rpm's.
When Vtec kick's in the turbo will choke the motor.
Hoosier Daddy
Mar 28, 2004 10:36 PM
