Is this safe to use / beyond repair?
Old Jan 26, 2008 | 02:23 AM
neil-ste's Avatar
Default Is this safe to use / beyond repair?
I was taking the bearings out of my block the other day so I could take it to the machine shop to be bored and honed. When I was taking the main bearings out I slipped and have marked on of the surfaces on the block. It's quite small, but I really don't know if it will be safe to use again, the marks stand proud a little from the surface and catch on a fingernail.
Oh, hi from a newbie in the UK too. This site is a damn sight better than anything UK based.
Old Jan 26, 2008 | 03:11 AM
b20vtechb's Avatar
Default Re: Is this safe to use / beyond repair? (neil-ste)
just take a small die grinder like a dremel with a sanding wheel on it and very lightly sand the area you messed up.. but only the parts that are sticking up and DON'T try and blend it out with the rest of the bore.
Old Jan 26, 2008 | 03:22 AM
neil-ste's Avatar
Default Re: Is this safe to use / beyond repair? (b20vtechb)
Will that be safe though? The last thing I want to do is spin a bearing or similar on my newly built block.
Old Jan 26, 2008 | 03:35 AM
non-VTEC's Avatar
since you are taking it to the machine shop......have them look at the marks. im sure they can lightly scuff the high spots down without any issues.
Old Jan 26, 2008 | 07:19 AM
ickyhonda's Avatar
Default Re: Is this safe to use / beyond repair? (non-VTEC)
A line hone will take care of it. When putting it back together just make sure that you plastigauge your bearings to make sure your bearings provide the correct clearance.
Old Jan 26, 2008 | 03:29 PM
johnlear's Avatar
Banned
Default Re: Is this safe to use / beyond repair? (ickyhonda)
Carefully file the high peaks off with a fine toothed needle file. Use a file with a gentle radius /curve across the width of the blade. Try not to file any of the 'flat' area, but a few slight scratches won't be an issue. Finish off by lightly rubbing with a very fine abrasive paper (1200 grit with the initial 'sharpness' worn off).
pacurcouch
Engine Machining & Assembly
Mar 30, 2019 04:59 PM
top end tuner
Dec 14, 2008 09:00 PM
Del_Sol_s
10
Dec 13, 2004 01:36 PM
Full-Race Geoff
Apr 10, 2004 07:50 AM
ludesleep
Jul 21, 2003 07:40 AM
