how many have just "bolted on" a block girdle?
Old 03-15-2004, 09:55 AM
Full-Race Geoff's Avatar
Default how many have just "bolted on" a block girdle?
I am interested in knowing how many people have just put a block girdle on their motors without checking the mains?
If you have, have you torn your engine down since and what did the #3 mains look like?
thanks
Old 03-15-2004, 09:59 AM
b18bturbo's Avatar
Default Re: how many have just "bolted on" a block girdle? (Full-Race Geoff)
hey geoff you mean without doing align hone and doweling just bolting on a kit and calling it quits.
Old 03-15-2004, 10:48 AM
95LSDOHC's Avatar
Default Re: how many have just "bolted on" a block girdle? (b18bturbo)
bump...id like to know too
Old 03-15-2004, 10:52 AM
Default Re: how many have just "bolted on" a block girdle? (95LSDOHC)
yeah just throwing it on an existing motor. I tore three motors aparts and the #3 mains looked the same, so i was just wondering what others have seen
Old 03-15-2004, 09:43 PM
leadfoot78's Avatar
What do u mean the same?? did all three motors spin a bearing, or were they fine?? I was researching that a while ago and I saw what u had said and a few other trust worthy people on H-T and I decided that I wasn't going to use a girdle. I will instead have the whole assembly balanced, bearing clearances checked and I will be using AEBS main studs on it.
Old 03-16-2004, 06:45 AM
Bnjmn's Avatar
Default Re: how many have just "bolted on" a block girdle? (leadfoot78)
A girdle is a good idea, just the amount of $$ to do it "right" (line honing the mains and doweling the girdle, and having the girdle machined if you are using a GSR girdle) would be equal or more than buying a GSR block.
Unfortunately I never used the LS shortblock that I built with a girdle, so I have nothing to add.
Ben
Old 03-16-2004, 07:30 AM
m R g S r's Avatar
Default Re: how many have just "bolted on" a block girdle? (Bnjmn)
Do you guys think I should just upgrade the bolts on my b16 (looking for around 500hp), instead of running a girdle? I don't really plan on revving past 8500 rpm's.
Old 03-16-2004, 08:32 AM
Default Re: how many have just "bolted on" a block girdle? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">Do you guys think I should just upgrade the bolts on my b16 (looking for around 500hp), instead of running a girdle? I don't really plan on revving past 8500 rpm's. </TD></TR></TABLE>
absolutely
Old 03-29-2004, 11:13 PM
InfamousRS's Avatar
Geoff. I had the bolt holes on my mains machined out to fit 13mm dowels (same as what align the mains to the block) for my Endyn girdle. The crank still spins as free (by hand) as it did with out the girdle. Do you think it would still be wise for me to have a line-hone done?
Old 03-30-2004, 11:05 AM
acy76's Avatar
Default Re: how many have just "bolted on" a block girdle? (InfamousRS)
When I installed the Endyn girdle on my B18A, the machine shop recommended the align hone to be certain everything was square. Apparently the girdle can really throw the mains out of whack when it's torqued down. The whole job ran around $600 parts + labor though, so it's not cheap by any means.
Old 04-10-2004, 03:47 AM
tegman2's Avatar
bump
Old 04-10-2004, 05:21 AM
rondigs's Avatar
Default Re: how many have just "bolted on" a block girdle? (tegman2)
I had my GSR girdle machined to fit the LS bottom (align hone and doweling).
Old 04-10-2004, 07:21 AM
tegman2's Avatar
Default Re: how many have just "bolted on" a block girdle? (rondigs)
How much was the align hone?
I have the Z-10 and had it doweled to the main caps already but not align honed yet. Im waiting to have my block sleeved first.
Old 04-10-2004, 07:37 AM
00siBuilder's Avatar
Last year i put one together and just bolted in a z10 it worked out fine no problems at all with it.
Old 04-10-2004, 07:50 AM
GEN2TEG's Avatar
I have a z10 on my ls/vtec setup and had a line hone done before it was put on. Better safe than sorry!
Icon_Ed6
11
07-10-2011 05:05 AM
krick182
10-11-2010 08:03 AM
CheezeFrog
04-02-2004 02:40 PM
Full-Race Geoff
03-15-2004 06:05 PM
VWkila
02-22-2003 10:47 PM
Quick Reply: how many have just "bolted on" a block girdle?
