Any good tips on removing balancer shaft bearings?
Im in the process of eleminating my balacer shaft bearings on my build cause I dont want to use the shafts. Im trying to remove them and put them back in to block off the oil holes. I keep tappin but no movement beaing keeps tearing up.
Re: Any good tips on removing balancer shaft bearings? (ludesleep)
anyone who has tried this mod? Should I just go buy some JB weld and seal up the holes on the bearings?
Guest
Posts: n/a
take the block to a machine shop and tell them what you want done, they will use a cam bearing tool (like the cam in block style V8s) to remove the bearings, then have them turned to block off oil feed, that's what i had done with mine
Let me/us know how this goes. I might be going through the same exact thing on my F22 block. Still haven't decided if I want to run w/o the balance shafts, but I'm leaning towards it.
