rebuild for t517z??? what do i need
Old Jan 25, 2008 | 02:52 PM
moores55's Avatar
Default rebuild for t517z??? what do i need
Ok i have a geddy kit on my ep3 now and i'm looking for a rebuild kit for it. I can find the 15, 16g kit's but nothing that says something about the t517z. Any help would be great.
Old Jan 25, 2008 | 11:15 PM
moores55's Avatar
Default Re: rebuild for t517z??? what do i need (moores55)
Ok, really boys? no one can help me.
Old Jan 26, 2008 | 08:34 AM
TheShodan's Avatar
Moderator
if the cartridge is indeed damaged, it is possible to use the cartrdige kits from the other 16g turbos. The only problem is that the GReddy uses a hybrid parts from 2 companies, Garrett and MHI. You actually may have to take it apart, or show a pic of the cartridge. That may help.
As for the Compressor wheel itself, you may have to go to Trust-Power to look up the actual wheel number..
Hpe that puts you in the right direction
Old Jan 26, 2008 | 12:36 PM
moores55's Avatar
Default Re: rebuild for t517z??? what do i need (TheShodan)
I'm starting to think it will be better to just buy a new one now. So the t517z is the same as a 16g? there is a very small amount of shaft play and it smokes at start up for 30 sec. and then is fine. so i'm guessing that it's just the seals.
GPRacing
Sep 11, 2013 09:39 PM
calumthestrong
Mar 23, 2011 11:44 AM
accord99power
Mar 23, 2011 10:55 AM
black98gsr-t
May 18, 2005 05:32 AM
Dinan330ic
Mar 5, 2005 10:19 PM
