rebuild for t517z??? what do i need
Ok i have a geddy kit on my ep3 now and i'm looking for a rebuild kit for it. I can find the 15, 16g kit's but nothing that says something about the t517z. Any help would be great.
Moderator
Re: rebuild for t517z??? what do i need (moores55)
if the cartridge is indeed damaged, it is possible to use the cartrdige kits from the other 16g turbos. The only problem is that the GReddy uses a hybrid parts from 2 companies, Garrett and MHI. You actually may have to take it apart, or show a pic of the cartridge. That may help.
As for the Compressor wheel itself, you may have to go to Trust-Power to look up the actual wheel number..
Hpe that puts you in the right direction
Re: rebuild for t517z??? what do i need (TheShodan)
I'm starting to think it will be better to just buy a new one now. So the t517z is the same as a 16g? there is a very small amount of shaft play and it smokes at start up for 30 sec. and then is fine. so i'm guessing that it's just the seals.
