What Motor?
Old Jan 24, 2008 | 10:26 AM
confusion's Avatar
Default What Motor?
I will be swaping the motor in my eg8 in a couple months but im just not sure which way to take it. I was thinking about a d16z6, then throwing a turbo on it later but im not sure. i do want to go turbo but im not sure if i want the single cam. so i have come to this conclusion, I either want to throw a b16, b18b w/ gsr trans, or a d16z6. i will be driving the car daily and i have plans for a turbo later. I would like to get your opinions on which motor. thanks
Old Jan 24, 2008 | 10:33 AM
ke98248's Avatar
Default Re: What Motor? (confusion)
If you have a few extra bucks, go for the b18b paired with a GSR tranny, you will love me for it later down the road. JK, but that's a better option than a d16z6.. you can get higher HP/TQ #'s and run more boost on it than the d16z6 (all stock internals).
However, if you're broke, get the d16z6 -- easy swap and cheap to replace.
Old Jan 24, 2008 | 10:34 AM
delslow05's Avatar
If i were you i would go with a b18b with a b16 tranny closer gear ratio. and single cams are horrible with bolt-ons. A b18b with 12psi crapped all down the throat of a stang on spray and that was untuned.
Old Jan 24, 2008 | 10:35 AM
ke98248's Avatar
Default Re: What Motor? (delslow05)
What kinda turbo -- that makes quite a bit of difference.. a t25 at 12psi makes far less than a t4 at 12psi...
Old Jan 24, 2008 | 10:46 AM
confusion's Avatar
Default Re: What Motor? (ke98248)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslow05 &raquo;</TD></TR><TR><TD CLASS="quote">If i were you i would go with a b18b with a b16 tranny closer gear ratio. and single cams are horrible with bolt-ons. A b18b with 12psi crapped all down the throat of a stang on spray and that was untuned.</TD></TR></TABLE>
how is the b16 tranny on the freeway though? i want the car to be fun but i do a lot of freeway driving and i have buddys with b16 trans and they have to wine the crap out of thier cars on the freeway
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 &raquo;</TD></TR><TR><TD CLASS="quote"> If you have a few extra bucks, go for the b18b paired with a GSR tranny, you will love me for it later down the road. JK, but that's a better option than a d16z6.. you can get higher HP/TQ #'s and run more boost on it than the d16z6 (all stock internals).
However, if you're broke, get the d16z6 -- easy swap and cheap to replace. </TD></TR></TABLE>
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 &raquo;</TD></TR><TR><TD CLASS="quote">What kinda turbo -- that makes quite a bit of difference.. a t25 at 12psi makes far less than a t4 at 12psi... </TD></TR></TABLE>
im not sure what turbo yet, i was thinking t3/t4
Old Jan 24, 2008 | 11:49 AM
nicks-eg6's Avatar
ls turbo... there cheap to source , fun turbo motors , and if you want vtec later on. get a b16 or gsr head.
Old Jan 24, 2008 | 01:17 PM
95teg_ls's Avatar
you could always put an ls 5th on a b16 or gsr trans, but if you are against that i would stick with the gsr.
Old Jan 24, 2008 | 03:53 PM
delslow05's Avatar
Default Re: What Motor? (95teg_ls)
yeah it wines pretty high at 65-70 but i like the gears in it but you could also go with what the guy said in your thread put a ls 5th gear in it and that would solve that problem. but if your lookin for MPG on the freeway i would go GSR trans.
Old Jan 24, 2008 | 03:57 PM
ek9=]'s Avatar
I say you throw a b16 in there. They are fun and higher revving then the other two choices
Old Jan 25, 2008 | 06:31 PM
confusion's Avatar
Default Re: What Motor? (ek9=])
thanks for the opinions, i think im going to go ls/gsr
93 Eg Couper
Mar 1, 2009 08:56 PM
Lil_Wyte
15
Oct 19, 2006 09:35 PM
thisisntjared
46
May 27, 2005 06:05 PM
v-tec_warrior94
Aug 13, 2003 07:54 AM
grippgoat
Jan 20, 2002 07:00 AM
