Suspension & Brakes Theory, alignment, spring rates....
Ground Control coilover spanner wrenches?
Old Jan 23, 2008 | 10:44 AM
inh's Avatar
inh
Default Ground Control coilover spanner wrenches?
Anyone know where I can get a set, or ones that will work? My CRX came with a set on it, but no wrenches anywhere in sight =[
Old Jan 23, 2008 | 10:57 AM
96hb's Avatar
Default Re: Ground Control coilover spanner wrenches? (inh)
As far as I know, GC's don't use a spanner wrench. Mine have an allen set screw in the collar, and if you loosen that up and the collar still doesn't want to spin, you can bump it a little bit with a flathead screwdriver and hammer. Also make sure the threads are clean before you try to adjust it.
Old Jan 23, 2008 | 07:25 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inh &raquo;</TD></TR><TR><TD CLASS="quote">Anyone know where I can get a set, or ones that will work? My CRX came with a set on it, but no wrenches anywhere in sight =[</TD></TR></TABLE>
You don't need one to adjust them (just loosen the allen-head pinch bolt and turn the perch by hand), but you can purchase the correct size spanner wrench from Ground Control.
http://www.ground-control-store.com
Old Jan 23, 2008 | 09:38 PM
bmoua's Avatar
Default Re: Ground Control coilover spanner wrenches? (96hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96hb &raquo;</TD></TR><TR><TD CLASS="quote">As far as I know, GC's don't use a spanner wrench. Mine have an allen set screw in the collar, and if you loosen that up and the collar still doesn't want to spin, you can bump it a little bit with a flathead screwdriver and hammer. Also make sure the threads are clean before you try to adjust it. </TD></TR></TABLE>
Old Jan 30, 2008 | 07:02 PM
hpi247's Avatar
Default Re: Ground Control coilover spanner wrenches? (bmoua)
i think you can call GC and order one. I use the old flat head and a hammer trick to budge them, then spin by hand.
Old Jan 30, 2008 | 09:02 PM
inh's Avatar
inh
thanks for all the ideas guys. I've yet to even see the collars in person, im in Iraq, car is at my parents place, hence the stupid question.
newbbb
Oct 22, 2008 02:16 AM
bayeg6
Apr 9, 2007 10:00 AM
HeikDiesel
Jul 1, 2005 11:06 AM
MikeHock
24
May 5, 2004 11:25 AM
SD_EM1
Aug 23, 2003 01:21 AM
