Black out EP3 hedlights
Old Jan 22, 2008 | 09:11 PM
johnclaunch's Avatar
Default Black out EP3 headlights
I will be painting the chrome housing of my headlights next week and I am wondering 1) what is the best paint to use (I currently have some TRIM BLACK that I picked up from a local professional paint shop that doesn't require primer.), 2) Since it is winter and cold (<40F) what is the dry time going to be like on the paint? Would it be better to heat the part in the oven at around 150-200 degrees for a bit to get it to dry or what? 3)What is the best method to disassemble the housings? Ephatch has a write up that includes placing them in a 200 degree oven to weaken the sealant and then pull apart, others have told be to just use a heat gun, any proven methods to save any headaches? Thanks.
Old Jan 22, 2008 | 11:40 PM
C4st0r_Tr0y's Avatar
Official H-T Cake Maker
Default Re: Black out EP3 headlights (johnclaunch)
any paint would work--
eaither way works..
put in oven is quicker just make sure you DONT touch the side of the oven or your expletiveed...then buy some silicone to seal the headlights back
Old Jan 24, 2008 | 04:14 PM
WhiteOnRice's Avatar
I'd only heat the oven to 100 degrees to cure the paint (or warm or w/e your oven says).
Old Jan 24, 2008 | 08:39 PM
Default Re: (WhiteOnRice)
Okay, so 200 to get the light apart and 100 to cure the paint. How long to cure in the oven?
Old Jan 24, 2008 | 10:30 PM
702egsi's Avatar
Default Re: (johnclaunch)
if your schedule alows it you could paint them in the morning and at night it would be dry glue them together and reinstall in the morning
Old Jan 25, 2008 | 08:25 AM
I don't remember what temperature to pull the lens off but I know a colder temp and longer is better than hot temp and short time. I melted tail lights doing that. I'd use the coldest temperature you find in a DIY.
Old Jan 27, 2008 | 07:48 PM
gthugdelux's Avatar
here... other posts dont seem to answer much...
here is the COMPLETE write up. (yes its for an RSX but same thing)
i did mine to this, came out PERFECT!
http://www.dc5nation.com/forum...=2708
99fbpem1
Aug 24, 2007 09:36 PM
RacingShoeBox
Oct 6, 2005 11:07 AM
SjCiViCHB
30
Apr 17, 2003 12:37 PM
hybridb18
Mar 29, 2003 10:14 PM
black2kcivic
May 23, 2002 10:09 AM
