F/H-series downdraft carburetor???
I was thinking of building a manifold similar to this one, instead of using just an H-series manifold
Then I thought about using a smallish 4-barrel carb, the smallest one i've been able to find is a 400cfm. What do you guys think, ps, this will be on my built F22A6.
Theres a fine line between bad *** and rediculous, I think it would take a dyno chart to convince me one way or the other. I know that type manifold kills on all motor K's, thats gotta be the first time I've seen a setup like that on a non K motor. I'd go single big *** throttle body vs. carb though... Carbs are cool if you have the time and patients for them, but short of bisi who would tune it? Need a throttle body like this
I've been thinking about this since I read it last night and saw this picture. Im pretty intruiged since my F has a very similar manifold design. There is a lot of room for improvement that I can see from that photo though, since its a round throttle body centered on top of a flat top plenum with lots of dead space from side to side. The image of an LT-1 throttle body came to mind, its two smaller butterflys in one housing, I think it would be a much smoother flowing unit with less turbulance and even greater incoming air capability. Maybe the next best thing to ITB's. I put a wanted add out for a stock LT-1 throttle body so I can try this out.
I used to have one of those, unfortunately it went with the car that it was atatched to when I sold it.
here's one on Ebay....cheap.
http://cgi.ebay.com/ebaymotors...ZWDVW
oooh, here's a modded one for $170
Modified by thehatchninja at 11:32 PM 1/22/2008
Since I've never had one of these in hand, I'm only guessing it would be a good size. Since you've had one before do you think it would fit nicely on there? Off the top of your head do you think it would fit on a plenum block off plate or would it hang off the sides?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AK_CRX »</TD></TR><TR><TD CLASS="quote">Since I've never had one of these in hand, I'm only guessing it would be a good size. Since you've had one before do you think it would fit nicely on there? Off the top of your head do you think it would fit on a plenum block off plate or would it hang off the sides?</TD></TR></TABLE>
you mean an f/h plenum plate like the one above? If so, yes it would fit nicely.
[QUOTE=thehatchninja]I was thinking of building a manifold similar to this one, instead of using just an H-series manifold
[QUOTE]
i have a dual throttle body setup with custom adapter to the H22 manifold for sale if you are interested. Pm me for details.
[QUOTE]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninethree-civic »</TD></TR><TR><TD CLASS="quote">arent those manifolds similar to the d16y7 mainifolds? something known not to flow well? </TD></TR></TABLE>
you're asking if an h-series manifold is similar to a y7... no, they are not similar at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22crxpwr »</TD></TR><TR><TD CLASS="quote">
i have a dual throttle body setup with custom adapter to the H22 manifold for sale if you are interested. Pm me for details. </TD></TR></TABLE>
pm'd
pm'd
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehatchninja »</TD></TR><TR><TD CLASS="quote">
pm'd</TD></TR></TABLE>
pm'd back. i'll take some pics of the setup soon.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehatchninja »</TD></TR><TR><TD CLASS="quote">you're asking if an h-series manifold is similar to a y7... no, they are not similar at all.
no i meant
the d16y7 engines have the "downdraft" style, and in the d series world are seen has crap intake minis becuase they do not flow to well
and i do know that the d will not bolt to the h
no i meant
no i meant
totally different manifolds.. comparing apples to oranges...
no i meant
Teamdiesel
10
Oct 26, 2007 07:00 PM
JforJonathan
10
Apr 10, 2004 12:15 PM
S2KILLA
18
Jul 28, 2003 02:11 AM
MotorMatrix.com
Jan 8, 2003 10:50 AM
