Type R Throttle Body and Intake Manifold, Whats the hp Barrier?? Tony1,earl,Jason??
I am a bad person
I am attempting to make over 600whp on a bigger turbo setup this week but I am thinking I may not be able to with the 63mm Type r TB and intake manifold. Has anyone made over 600whp with a similar setup?? If I'm going to be stuck at 550-575 because of the airflow, I will get a new manifold and throttle body. If anyone has experience with a similar setup and info will be great. thanks
Re: Type R Throttle Body and Intake Manifold, Whats the hp Barrier?? Tony1,earl,Jason?? (MotorMatrix
Lisa Kubo is still running a type r manifold, she's gotta be making at least 750whp, probably closer to 800. I've never really tried to push the type r manifold to far, always gone with a jg or something. Lisa and Gary have a thing against jg so they stuck with the type r. They did buy one of our motors from us at Atco because she blew hers up. It had a jg edlebrock manifold and they ran their fastest time at that time with our motor. If that tells you anything...
What size piping are you running? If it is 2.25", probably about 65mm tb is all that you can use. If it is 2.5", your 63mm will probably choke you down. If bigger than 2.5", it goes off my chart. Actually, I don't have a chart, I'm just talking out my ***
I am a bad person
I can't say whether you will or won't but if you do, it should open up some eyes. Would be an accomplishment.
1 Post
Ever thought of porting that ITR Manifold?
A certain someone is running a VERY NICELY PORTED ITR Manifold on their all-motor setup. Can't give it away tho...
Suprdave
Suprdave
Maybe call ExtrudeHone and get the Type R "Kubo signature series" manifold.
New User
agreed. I had one done by extrude hone, I picked up 4hp n/a no other changes, gains everywhere above 5.5k. I imagine it would show greater gains with boost.
Suprdave
Suprdave
stan
I am a bad person
here is the thing. I am not looking to extract every bit of hp out of the intake and throttlebody. I already have more hp than i need for the street setup i run. I'm just looking to reach my 600hp goal w/o switching manifolds and throttle body.I thought maybe someone on here has already gone over 600 or heard of someone over 600 with a similar setup to mine. or attempted it and had problems until switching manifold and throttle body.
Smarter than you
if swapping to a new manifold will see good gains then I cant see why you wouldnt want to do it when the type R mani can easily sell for 200$ and get back that much of whatever u spend on the new mani. but on the other hand, personal preferance here, but the ITR/skunk 2 mani just looks really good when u pop the hood i like the oem-ness.
New User
I am a bad person
A good friend of mine was using a unmodified Skunk2 manifold generating over 600hp, he just revved the **** outta it
by the way john, what is honestly the most hp to the wheels you have seen or tuned on hondata??
New User
As far as I know, you're the highest I've seen or heard of on Hondata. I don't understand why people think that Hondata can't support high hp, it's computers are as fast as Haltech's, and it can idle big injectors no problem. It's only real limitation is the boost it can meter, 28psi. Sure, I wish it had more tunable points, but I say that about just about every management system I've used Beyond that, it works very well.
The worst that could happen with the ITR parts is your intake temps going up.
I forgot who said it by time I got down here, but when you bore a TB you can change out the butterfly. Directed a Flamenco-T, but I'm sure you already knew this.
[Modified by tzsir, 6:45 AM 1/8/2003]
Well I ran a bored out stock ls t body from jg, and a skunk 2 intake manifold, I hit 150 with those, I dont know my how much power my car made, it weight 2140 that day so someone can do the math. I think you can make 600 with your setup, others may disagree. This year is the first time I am gonna have a bling bling, holley 68mm t body, and Venom intake manifold, it is ashme it will be in a new car so I wont know the gains, but plenty of people have gained from the Venom or Jg manifolds. I would go to the dyno and see, if you have access to it you can answer your own question, if you can keep it from spining, heheh. Jason
ricanpapi102
01-30-2008 04:51 PM
