Lighting HID/Xenon kits, Retrofits and Associated Topics
removed fogs alarm doesnt work.
Old Jan 21, 2008 | 03:23 AM
jiggatone's Avatar
Default removed fogs alarm doesnt work.
i had pwjdm fogs and viper alarm.i had to sell my fogs so i took it off yesterday and now my alarm wont work??i took out only and touched only the fog light wires.this happened after i d/c'd the fog wire off the battery.everything works fine though lights electronics etc.anyone got a clue?
Old Jan 21, 2008 | 11:32 AM
bpr0422's Avatar
Default Re: removed fogs alarm doesnt work. (jiggatone)
you most likely blew the fuse going to your alarm
or disconnected the alarm's battery source.
replace the fuse, or reconnect the alarm...
Old Jan 22, 2008 | 08:01 AM
JDMedgar's Avatar
You most likely blew a fuse or diconected the main 12v wire that goes directly to the alarm...
check the wiring again
Old Jan 27, 2008 | 07:47 AM
vietxdragon's Avatar
you might also have to get your alarm brain reprogrammed? My car died once and my alarm had to be reprogrammed because once the power is fully gone and no battery for the brain to run off it 'll need to get reprogrammed. not sure if its the same in your case though
lahrlax
Audio / Security / Video
Jul 21, 2017 02:41 PM
1BADEGDC2
Dec 30, 2008 04:29 PM
SamC
Apr 29, 2008 01:14 AM
ctownintegra
Mar 10, 2008 08:24 AM
frog169
Sep 16, 2006 11:19 PM
