88 rex si...where is the plug to get CEL codes?
i
habing a hard time finding the plug that i'm suppsed to conect, and make the light blink i dont even find the CEL list.
help me locate the plug on my car. thnks.
https://honda-tech.com/zerothread/1901557
oh sorry i forgot to mention that i did a swap for a gsr obd1 and i currently have a OBD 1 ECU how would that work.?? thanks.
also ow do i run the sensor on the thermostat housing and the vtec wire(oil pressure and solenoid)? thaks alot for you help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dead CIVIC »</TD></TR><TR><TD CLASS="quote">oh sorry i forgot to mention that i did a swap for a gsr obd1 and i currently have a OBD 1 ECU how would that work.?? thanks.
also ow do i run the sensor on the thermostat housing and the vtec wire(oil pressure and solenoid)? thaks alot for you help.</TD></TR></TABLE>
heres the list
http://www.hondacivicforum.com/m_45386/tm.htm
heres the list
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dead CIVIC »</TD></TR><TR><TD CLASS="quote">oh cool but how do i get the lightto start flashing?</TD></TR></TABLE>
that all depends on the jumper harness you have, It should have all the info in the jumper harness instructions that came with it
