vtec light CEL
Old Jan 19, 2008 | 05:19 PM
ge_ej1's Avatar
Default vtec light CEL
anybody have this problem....i hooked up a vtec light and the light has a built in resistor....when its cold, and i mean cold, i get a CEL, i believe its from me tapping into the ECU, and when the temp hits normal operating temp i can restart up the car and the CEL is gone, is this normal? i haven't really ran a test to see what the CEL is though...
Old Jan 19, 2008 | 05:22 PM
z6hatchboy's Avatar
Default Re: vtec light CEL (ge_ej1)
It shouldn't be from where you tapped it. Sounds like ect(engine coolant temp) sensor maybe.
Old Jan 19, 2008 | 05:37 PM
ge_ej1's Avatar
Default Re: vtec light CEL (z6hatchboy)
but it has only been doing that since i tapped my vtec wire into my ecu
Old Jan 19, 2008 | 05:39 PM
z6hatchboy's Avatar
Ah i see, i have a light as well in mine, i havnt had the problem. Which did you tap?
Old Jan 19, 2008 | 05:44 PM
ge_ej1's Avatar
well mine is an obd1 and first i tapped it into my green with yellow wire, found out that was my fuel pump wire...then i tapped it into my orange with yellow wire....
Old Jan 19, 2008 | 05:48 PM
z6hatchboy's Avatar
You should've tapped the orange/white vtec solenoid wire. I used one of the the clips with a metal bridge tap to tap them.
Old Jan 19, 2008 | 05:54 PM
ge_ej1's Avatar
yea, that's the one....haha...i cut the whole wire off and tapped it in that way, but tomorrow i am going to use heat shrink on it, maybe that will help....but i guess its nothing bad though, it has only been throwing me that CEL because its been so damn cold in WI. its been below 28 degrees this whole week and gets colder....
mrsideways
Aug 20, 2007 12:40 PM
civictype-r
20
May 17, 2006 03:36 PM
quik2kSi
Jun 24, 2002 01:38 PM
Stu
Sep 4, 2001 10:53 PM
