does anyone else change there oil filter from the top?
Old Jan 19, 2008 | 02:49 PM
socallmechris's Avatar
Default does anyone else change there oil filter from the top?
i was too lazy to climb all the way under tonight changing my oil. i then realized i could just get to it from the top. its not supoer easy, but it works.
is anyone else as lazy as me, or am i the only one doing it this way?
Old Jan 19, 2008 | 02:54 PM
-JSpecEk*9-'s Avatar
Default Re: does anyone else change there oil filter from the top? (socallmechris)
i havent tryed it yet. i always put my car on a hoist to do my Oil Change.
Old Jan 19, 2008 | 02:56 PM
97Ej6mike's Avatar
Always gone from the bottom. You might as well, your down there anyway to get to the plug. Seems simpler than straining from the top.
Old Jan 19, 2008 | 03:04 PM
JSPECSIR's Avatar
Default Re: (97Ej6mike)
ive always done it from the top. i just reach between the im and the brake booster. put it back on the same way.
Old Jan 19, 2008 | 03:06 PM
95vxtealhatch's Avatar
yep i change mine from the top
Old Jan 19, 2008 | 03:13 PM
DOHChatchGUY's Avatar
Default Re: (95vxtealhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95vxtealhatch &raquo;</TD></TR><TR><TD CLASS="quote">yep i change mine from the top</TD></TR></TABLE>
same here. its just easier for me that way...and ima lazy *******.lol
Old Jan 19, 2008 | 03:19 PM
Dann6968's Avatar
Default Re: (DOHChatchGUY)
Isn't it really messy if you do it from the top?
Old Jan 19, 2008 | 03:41 PM
helpbobEm1's Avatar
always done it from the top, hate the idea of havin oil spill on me or my face by accident underneath. it does spill a lil bit of oil around, but nothing a quick wipe with a towel cant remedy. only precautions is to be careful of the sharp parts when ur pullin it out so you dont stab/scrape your arm/hand on anything.
Old Jan 19, 2008 | 08:51 PM
Default Re: (helpbobEm1)
when i do it from the bottom, i always end up covered in all kinds of stuff some how.
i can reach the drain plug without climbing all the way under. the only thing is i still have to jack it up cuz my catch pan doesnt fit under now that i lowered my car.
Old Jan 19, 2008 | 09:01 PM
green-'s Avatar
Default Re: (socallmechris)
Who the expletive cares if you do it from the top or bottom
Old Jan 19, 2008 | 09:35 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: (green-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green- &raquo;</TD></TR><TR><TD CLASS="quote">Who the expletive cares if you do it from the top or bottom</TD></TR></TABLE>
Agreed.
It's really only possible from the top if you dont have PS. Unless you have little guhhhrly ahhrms.
Old Jan 20, 2008 | 04:21 AM
JSPECSIR's Avatar
Default Re: (B serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote">
Agreed.
It's really only possible from the top if you dont have PS. Unless you have little guhhhrly ahhrms. </TD></TR></TABLE> i have ps on both my civics, and my arms are pretty big.
Old Jan 20, 2008 | 05:46 AM
Syndacate's Avatar
Default Re: (JSPECSIR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by socallmechris &raquo;</TD></TR><TR><TD CLASS="quote">i was too lazy to climb all the way under tonight changing my oil. i then realized i could just get to it from the top. its not supoer easy, but it works.
is anyone else as lazy as me, or am i the only one doing it this way?</TD></TR></TABLE>
Hey man, stop me if I'm wrong but from what I remember there's sort of an alternator, power steering pump, intake manifold, strut tower, so on and so forth in your way, no?
It's not the easiest filter to access from the top, that's for damn sure. I change mine from the bottom. Damn, I'm quite sure that if I tried to access it from the top I would have no luck and if I actually was able to grab it I doubt I'd be able to apply much torque to remove it - unless it's got grip tape - but even then, when your arm is bent the torque you can make sucks.
Old Jan 20, 2008 | 06:42 AM
afstvx's Avatar
yeah its actully much easier from the top so you dont get oil in your face. but to each his own. and hey syndacate your sarcasm only reflects your ignorance and stupidity, but hey what ever it takes to be a forum *****.
Old Jan 20, 2008 | 07:35 AM
instrument's Avatar
i hit it from the top, its a lot easier that way seeing you dont have to jack the car up as high or use jackstands/etc.
Old Jan 20, 2008 | 09:44 AM
importdreamer's Avatar
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
It's not the easiest filter to access from the top, that's for damn sure. I change mine from the bottom. Damn, I'm quite sure that if I tried to access it from the top I would have no luck and if I actually was able to grab it I doubt I'd be able to apply much torque to remove it - unless it's got grip tape - but even then, when your arm is bent the torque you can make sucks.</TD></TR></TABLE>
How the hell is the ps pump, strut tower, and the alternator in the way? Assuming the you look at the engine like a compass the ps and alternator would be in the southeastish part of the engine bay, while the oil filter is in the north. (I know that's a lame way to describe it but I don't think I have to post pictures to explain)
J.nguyen
Oct 13, 2006 06:45 PM
Thasty
Honda Motorcycles
Sep 4, 2004 08:28 PM
lowgman
Apr 21, 2004 04:14 PM
Floyd
Sep 23, 2003 07:08 AM
