overheating=blown headgasket??
Old Jan 18, 2008 | 06:42 PM
black0hatch's Avatar
Default overheating=blown headgasket??
i was driving on the high way and the u hose busted and my car violently overheated i got to the red for a second smoke was coming out of my valve cover. i fixed the hose and everything was all good till i drove on it hard on the freeway it started to over heat a little just went a little over half way then it would be normal then do it again and it does it intown sometimes if i drive on it for a while. is my head gasket starting to go?
Old Jan 21, 2008 | 06:27 PM
eastisle's Avatar
Default Re: overheating=blown headgasket?? (black0hatch)
did you change your thermostat? It probably stuck because of the heat.
Old Jan 21, 2008 | 07:58 PM
gourley's Avatar
Default Re: overheating=blown headgasket?? (eastisle)
Check/replace your thermostat and gasket.
Check/replace your "U" hose and clamps
Check/replace if needed all the coolant hoes'
Old Jan 21, 2008 | 08:23 PM
helpmycivic's Avatar
is your car smoking at all? had the same symptoms in my buddys ef ls hatch and it had thick white smoke coming out the tail pipe and ended up being the head gasket so it a def possibility. i would change your thermostat FIRST though since its alot cheaper then a head gasket. lol anyways good luck.
Old Jan 22, 2008 | 07:50 AM
Default Re: overheating=blown headgasket?? (helpmycivic)
no no smoke i dont think the headgasket is bad. if the thremostat was stuck open it would over heat? the car doesnt over heat anymore though.
Old Jan 22, 2008 | 10:00 AM
gourley's Avatar
If it was stuck closed it would, It wouldnt allowed water to pass through the head.
NENET
Jun 19, 2010 11:02 AM
D3vin
14
Mar 14, 2010 08:41 PM
Cleft_Asunder
Jul 12, 2008 08:11 AM
prendi
Aug 22, 2003 02:10 PM
Eg6_JDM
Aug 20, 2002 06:01 PM
