Removing Spoiler
Old Jan 17, 2008 | 07:27 PM
matmcg's Avatar
Default Removing Spoiler
can I get a step by step to remove it safely
also if anyone doesnt mind posting some pics without spoilers
Old Jan 17, 2008 | 07:43 PM
blackcherry's Avatar
all you have to do is remove the plastic lining on the inside of your hatch (on top or actually the underside of the hatch) and then you will see the 2 bolts on each side. remove them, then unhook the 3rd brake light wiring clip. remove spoiler...... if you want to see a wingless spoiler look in the ost pics of ur integra: thread and look for wingless tegs. alot of ppl have them or search for wingless. btw if you go wingless you will have a holy trunk unless you fill them or go cf
***EDIT**** the first integra in the post pics of your integra thread is wingless
Old Jan 17, 2008 | 07:45 PM
98BabiGs-T's Avatar
Default Re: Removing Spoiler (matmcg)
Assuming your talking about the stock spoiler.
- Open the hatch
- Remove the black covering under the hatch
- Disconnect the 3rd brake light harness
- Unbolt the bolts holding the wing
- Take the wing off (make sure the harness comes out the hole...)
Half-assing
- Open the hatch
- Cut the 3rd brake line/harness
- Remove wing
Old Jan 17, 2008 | 08:35 PM
matmcg's Avatar
Default Re: Removing Spoiler (98BabiGs-T)
yeah it looks really clean and less sporty i am sick of getting pulled over , i am probly gonna go wingless
Old Jan 17, 2008 | 08:42 PM
posHonda's Avatar
Its very simple and please dont cut the wires it is not that hard unplugging it. Pull off the plastic panel and im sure you can easily figure out the rest from there. Its VERY easy to do.
Old Jan 17, 2008 | 08:54 PM
matmcg's Avatar
Default Re: (posHonda)
sounds good , and is it necessary for me to weld or can i just use bondo... id rather not weld
Old Jan 17, 2008 | 08:56 PM
integra_661's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98BabiGs-T &raquo;</TD></TR><TR><TD CLASS="quote">
more pics please
Old May 1, 2010 | 06:01 AM
Teggy_fella's Avatar
Could someone link a step by step?
Old May 1, 2010 | 06:14 AM
kcon's Avatar
Once you have the spoiler off just take to a local body shop to weld the bolt holes and then do bondo yourself so you can save money. If you just bondo and fill it could crack with the closing of the hatch all the time
chatman_55
Feb 7, 2008 06:13 PM
jep
Jun 2, 2006 06:07 PM
philibuster
Dec 10, 2003 02:55 PM
EgSick
Jan 5, 2003 11:26 AM
PnX-R
Feb 8, 2002 12:48 PM
