having problems removing driver airbag...need help
Old Jan 17, 2008 | 04:44 PM
97civic123's Avatar
Default having problems removing driver airbag...need help
i'm trying to remove the driver side airbag out of my ek. So far i managed to stripped the star screw on the sides. They're not budging. there is some of the screw left to grab on, but i don't want to try again until i have a game plan. anyone have any ideas, or easy way to get it off. .
Old Jan 18, 2008 | 01:49 PM
97civic123's Avatar
Default Re: having problems removing driver airbag...need help (97civic123)
anyone
Old Jan 18, 2008 | 02:05 PM
Hittnthebz's Avatar
Squirt some pb blaster on it and letr it sit, tap it with a hammer, let it soak. Make sure you are using the right size bit.
Old Jan 18, 2008 | 02:14 PM
Hittnthebz's Avatar
You need a T30 bit.
Old Jan 18, 2008 | 02:52 PM
bart2546's Avatar
Default Re: (Hittnthebz)
If you can still get a grip with the bit, you may be able to get it loose by turning it the way you would tighten it first. NOT TO FAR THOUGH, just a little tug in the opposite direction to break it loose. I tend to have good luck using that method on bolts/nuts that are in dry places that have to be torqued tight.
Old Jan 18, 2008 | 07:41 PM
ca-rs's Avatar
Default Re: (bart2546)
I had this problem the other day. Stripped out the bolt b/c I tried using a t27, broke my t30. Ended up using and Bolt out socket type thing sold at sears. Tapped it a little with hammer it it came right out.
Old Jan 18, 2008 | 07:44 PM
Hittnthebz's Avatar
Default Re: (ca-rs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ca-rs &raquo;</TD></TR><TR><TD CLASS="quote">I had this problem the other day. Stripped out the bolt b/c I tried using a t27, broke my t30. Ended up using and Bolt out socket type thing sold at sears. Tapped it a little with hammer it it came right out.</TD></TR></TABLE>
Good to know in case the threads are too stripped to work with.
Old Jan 18, 2008 | 08:48 PM
mckrank313's Avatar
you can use a stripped screw remover. most auto part stores sell bolt removers.
To use them you drill a little, Take a hammer tap in the bolt remover and you can use a drill to pull it out (or a cresent wrench to turn it)
lmike6453
Jun 4, 2008 07:15 PM
b16greenmachine
27
Sep 17, 2007 08:44 AM
AdReNaLiN
Apr 2, 2006 01:57 AM
gtowni3
14
Apr 15, 2005 06:59 AM
allmotorEG-SI
Oct 3, 2001 11:14 AM
