K20 roll call Axle related
Old Jan 17, 2008 | 02:35 PM
ICeDoUt's Avatar
Default K20 roll call Axle related
Since K20a.org is all over the place with this question i wanted to start another thread here to see if there is anyone else out there, with new options.
Please only respond if you can list the following:
1) motor
2) motor mount kit used
3) transmission
4) type of car (88-91) hatchback, crx, sedan.... (don't respond if it is not listed)
5) amount your car is lowered
6) axle combination (ex: dss stage 2 axles, or rsx type s axles with b series outers, or straight up base axles)
7) was this setup road tested?
yes it seems like a lot, but every car is different. I think that this is the most relevant info needed.
any help would be great appreciated
Old Jan 17, 2008 | 03:17 PM
STREETWERKZ's Avatar
Default Re: K20 roll call Axle related (ICeDoUt)
1) motor - K20a
2) mount kit - Hasport EFK1
3) transmission - K20a
4) chassis - 90 CRX si
5) amount your car is lowered - 2.5" on Junk2 sleeves, new setup coming soon
6) axle combination - RSX base axles
7) was this setup road tested? - NOT YET
Old Jan 18, 2008 | 04:23 AM
ICeDoUt's Avatar
Default Re: K20 roll call Axle related (STREETWERKZ)
base axles with yoru setup, don't you think your going to snap them?
Old Jan 18, 2008 | 06:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ICeDoUt &raquo;</TD></TR><TR><TD CLASS="quote">base axles with yoru setup, don't you think your going to snap them?
I have 2 sets with lifetime warranties. For the price, I figured I would give them a shot. If they don't work out for me, I'll look for an upgrade. I only see a realistic problem with breaking axles if and when I decide to use slicks. That is why I have 2 sets.
Old Jan 20, 2008 | 06:27 AM
ICeDoUt's Avatar
i know theres not only one person on this forum with a K20 ef
Old Jan 20, 2008 | 07:52 AM
kid-honda's Avatar
1) motor - K20a
4) chassis - 91 CRX si
5) amount your car is lowered - 2 inches
6) axle combination - waiting on DSS axles
My answer is close to streetwerkz
Old Jan 20, 2008 | 01:59 PM
4DRmafia's Avatar
is t really hard to do ? is it better off prep the engine bay 1st and everything done then motor/ tranny come last?
Old Jan 20, 2008 | 03:41 PM
ICeDoUt's Avatar
Default Re: (4DRmafia)
it's not a hard swap to do, just involves more money and some welding ability.
Anyone else with some tested options
Old Jan 20, 2008 | 05:39 PM
4DRmafia's Avatar
bec i am really temping to do this, i dont mean to thread jack either
Old Jan 21, 2008 | 05:39 AM
rexman's Avatar
1) motor - K20A2
3) transmission - K20A2
4) chassis - 90 CRX Si
5) n/a
6) axle combination - DSS Stage1
7) was this setup road tested? - yep, been to "N13" Annual Niagara CRX Meet Ontario, Canada
Old Jan 21, 2008 | 02:43 PM
black_krix_si's Avatar
Default Re: K20 roll call Axle related (rexman)
1) K20A2
2) Hasport
3) type s 6spd
4) 91 crx hf
5) eibach sportlines so something like 1.5in or so
6) base axles
7) I drove this swap in an 88hf from clearwater florida to roanoke, virginia. I putting the same stuff with the exception of the eibach springs on another crx.
Old Jan 22, 2008 | 03:25 PM
ICeDoUt's Avatar
Default Re: K20 roll call Axle related (black_krix_si)
was there any binding that you noticed while driving the car with the base axles?
Old Jan 22, 2008 | 04:42 PM
i didnt notice anything wrong other than a bad wheel bearing but thats not fault of the axle.
Old Jan 22, 2008 | 05:41 PM
have you raced on the base axles yet?
Old Jan 24, 2008 | 04:51 PM
not yet. I drove the car home 500+miles then started pulling it apart to swap to a different crx.
Old Apr 27, 2008 | 03:56 PM
ICeDoUt's Avatar
well since i just installed my axles i figured i'd list my setup as an update
1) motor - K20a2
3) transmission - K20a2
4) chassis - 90 CRX Hf
5) amount your car is lowered - 2.5 inches
6) axle combination - rsx base
7) was this setup road tested? - sort of
As i went to reverse out of the garage, the axle "popped" not out of the intermediate shaft or the hub, but the axle joint, like it was stretched. This is the passenger side axle.
I have a feeling that axles are going to be a headache for me with this swap. I am going to try to take out the axle and put it back in and see how that works.
Old Apr 27, 2008 | 04:10 PM
pushit84's Avatar
I wish i was baller and had a k20a in my rex
Old Apr 27, 2008 | 05:34 PM
zrickety's Avatar
Default Re: K20 roll call Axle related (pushit84)
if the axle is stretched, or popped out already, why just take it out and put it back in? you're lucky it happened in the driveway and not on the road. i hope you find a solution
edit: sorry no k-swap yet, i forgot not to post. you can delete this if you want, i'd just hate to see anything bad happen to you or your ride
Modified by zrickety at 6:54 PM 4/27/2008
Old Apr 27, 2008 | 05:48 PM
NHswaps13203's Avatar
From: Swapin Motors,Tuckin Bays and Making Harness, CT, USfukenA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">1) motor - K20a
4) chassis - 91 DX Hatch
5) amount your car is lowered - all the way lowered on D2's
6) axle combination - Euro R driver side on pass side, RSX base with 36mm end
7) was this setup road tested? - All day everyday, beat the brakes off that bich, also i have jdm itr 36mm five lug
Old Apr 27, 2008 | 06:02 PM
ICeDoUt's Avatar
Default Re: K20 roll call Axle related (NHswaps13203)
^ yea but you have 5 lug, you didn't mention that part!
Old Apr 27, 2008 | 06:19 PM
hahaha read number 7
Old Apr 27, 2008 | 06:34 PM
DCFerris's Avatar
here ya go this should help you out a little http://www.norcalcrx.org/dropp...o.htm
Old Apr 27, 2008 | 07:05 PM
ICeDoUt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NHswaps13203 &raquo;</TD></TR><TR><TD CLASS="quote">hahaha read number 7 </TD></TR></TABLE>
It wasn't in bold, i can't read wasn't not in bold..
Plus you quoted streetwerkz which confused me even more, hahaha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCFerris &raquo;</TD></TR><TR><TD CLASS="quote">here ya go this should help you out a little http://www.norcalcrx.org/dropp...o.htm</TD></TR></TABLE>
Yea i am just trying to get an idea of what everyone is using, since there are multiple setup to use, thanks for the info
Old May 30, 2008 | 09:30 AM
ICeDoUt's Avatar
just thought i'd update this. The axle problem i thought i had was more like a transmission problem.
what i thought was a great deal on craigslist turned out to be a piece of ****, which i should have known coming from craigslist
Take a look:
Well now it gave me a reason to rebuild with a BRAND NEW 2nd gear set, and LSD. trans rebuild done by me, feels awsome now.
IN CONCLUSION:
Base axles are working on my setup will update again when i test it against 22" slicks
DC2-ProdUcTiOnS
12
Sep 4, 2012 08:43 AM
aemintgsr
K Series
15
Sep 9, 2009 06:43 AM
baxter04
Nov 16, 2004 10:02 AM
